Radios in Workmaster Series
/ Radios in Workmaster Series #1
Mike_in_Missouri
New Holland Workmaster 120 (decoration?), Massey Ferguson 135 (does all the hay work)
I have a 2023 Workmaster 120 and am not impressed with the radio. I cannot see the display, ever, regardless of how bright the intensity is. Is there a better quality radio available for these? I assume they are a standard automotive form factor and any unit of similar impedance/wattage would be fine for the speakers in these tractors.
/ Radios in Workmaster Series #2
I’m pretty sure the Kubota dealer got my radio they installed from the nearby Walmart. $100 Pioneer with Bluetooth. (They charged me $200) I believe the only issue is getting the proper wiring harness.
/ Radios in Workmaster Series #3
It shouldn't be too hard to get a wiring diagram for the original radio. A plug with pigtails typically comes with a new radio along with its wiring diagram. Match up functions and make the connections. Easy-Peezy. (y)
Edit: If this idiot can do it, anybody can.
/ Radios in Workmaster Series #4
I have two of those... Both my PowerStar tractors have the same radio you have in the Workmaster.
While they work, I'm less that impressed as well. My PS120 radio display has started weakening as well.
farmradiosupply.com has pretty much all adapters and options for radios. Some are pretty spendy.
2021 JOHN DEERE 410E SERIES II OFF ROAD DUMP TRUCK (A65053)
2021 JOHN DEERE...
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
2015 Kubota ZD1211RL 74in Zero Turn Mower (A64553)
2015 Kubota...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
