Exhaust popping, losing power when hot
   / Exhaust popping, losing power when hot
I know just how you feel about the old Ford. My 1951 Ford 8n is down and out right now with some type of electrical issue. That tractor is loads of fun when it’s running but is a real bear to do maintenance and repairs on. Even an oil change is a pain. And what’s up with having to remove the hood and gas tank anytime you need to do just about any work on it ?
I’ve said it many times, because there’s lots of truth to it: My favorite thing about owning one Ford and one Farmall tractor is the appreciation that they give me for the John Deere’s which have done most of the work at our farm, since grandpa got rid of his last team of horses, back in 1950.
At least the later models had the side mount distributor. I know every time I reach in for that front mount distributor to do something with it, I'm gonna need a bandaid or 2!
   / Exhaust popping, losing power when hot #12
Not saying it is your issue, but one of my Allis CA's was "popping" but otherwise started and ran fine. I just had to do a valve set and it went away.
On mine, I could hear the popping through the intake.
   / Exhaust popping, losing power when hot #13
Do you remove the distributor to tune or maintain it?
   / Exhaust popping, losing power when hot #14
Valve or spark timing. If you set the point & plug gaps right and you got a good condenser (lots of complaints about cheap chinese made condensers), setting timing is the only remaining thing to the tune-up. You said you replaced the distributer -- I'm assuming the cap, how about the rotor? If you replaced the whole distributer, or removed it, did you line it up the same on reinstall? If valve lash is at specs & springs/seats/rocker arms are ok, try advancing the spark timing if the pop is exhaust/****** if intake & carb popping. Any arcing on the wires? If none of those fixes it, your next step would be to check timing chain/gears for proper crank/cam positioning.
   / Exhaust popping, losing power when hot #15
Spark Timing is the first thing I would check. Setting it takes a timing light and one screwdriver. You just loosen the distributor and then tighten it when the light shows you the right position. The only mechanical check is to verify that the advance is working.
The whole whole timing procedure doesn't take 15 minutes.
Anyone who has a timing light can do it if you never have.
Spark timing is rarely required unless you have been doing work on he distributor work.
rScotty
   / Exhaust popping, losing power when hot #16
rScotty
That process does not work for the Ford front-mount distributor. You have to static-time them and you can do this with the distributor off the engine and on your work bench. You can get a tool to help with this on eBay: Locking & Align Tool for Timing Front Mount 8N, 9N/2N Ford Tractor Distributors. | eBay
   / Exhaust popping, losing power when hot #17
If it was ignition timing it should have the problem both cold and hot, not just when it’s hot.
   / Exhaust popping, losing power when hot #18
Yes, it would be nice if other manufacturers had copied Ford's lead and designed a keyed system so the distributor could only be assembled in one way. But there are enough downsides with modern gasoline that maybe we should be glad they didn't.
On lots of early engines, using a timing light for the first time requires mounting a pointer, a degree wheel, and painting a few marks on flywheel or engine pulley.
Paintng or filing timing marks on an early engine turns a 15 minute job into a two hour job the first time. After that, it's simple again.
But I wasn't saying that the popping was caused by timing. What I was sayng is that when you are looking for a problem it makes sense to start with the simplest and work towards things that are more complicate . For a mechanc, that is ignition and ignition timing - because the most common culprit in hot running if the radiator is doing it's job retarded ignition. Next comes another look at the cooling, the radiator & thermosta. Followed by carburation where lean running like a leaky intake manfold or plugged jet can cause overheating and those also can cause pre-ignition popping. Some time during that process we check for burnt or valves not sealing for some reason with a compression check.
All of these things are still in the realm of the home hobby mechanic, and my bet is that one will cure it.
But it needs a systematic approach, not a shotgun diagnosis.
   / Exhaust popping, losing power when hot #19
I thinking Head problem. Bad Gasket pressuring up the Sys. and getting hot to a bad/burnt, valve/Valves not seating. Hot or cold should be the same I agree on a timing problem. Getting hot is a good sign of a problem.
I've narrowed it down to a specific at least. I am getting a weak spark when it starts and then as it runs the spark gets weaker as the battery dies. I replaced the generator and VR already with a new generator and cutout but it doesn't appear that I am getting any output to the battery/coil. So, when I increase the RPM's or put it under load the cylinders start missing and it eventually dies. If I remove and charge the battery seperately it will run off the battery at full power for about 30 minutes and then slowly start missing again. I have 6V at the battery (not running) and the same voltage when it is running so I am assuming that the new generator/cutout isn't working and the coil, slowly, doesn't get enough voltage to keep it running. At best I get an orange spark on the spark checker that fades when applying more throttle. it also runs longer and better if I jumper the ballast resistor so I'll have the shop check the new generator/cutout. This has really gotten to be a long process...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
