   / Share Pics of People Hauling or Towing Something Wrong #20,571
In Minnesota, most people call a tractor trailer is a semi
I always thought the name was applicable to any trailer in which nearly 50% of the trailer weight is sitting on the tow vehicle, by historical context.
   / Share Pics of People Hauling or Towing Something Wrong #20,572
Yep, full (or pull) trailers are pretty rare, the ones that support all their weight, except for the minuscule weight of the draw bar/tongue.
If they don't have an axle, or axles, in each end they're semi trailers, but watch people being in complete denial when pointing out that their regular trailer is a semi trailer. Be it for a boat, a basic flatbed, or whatever.
   / Share Pics of People Hauling or Towing Something Wrong #20,573
I'm no expert, but I always assumed the distinction was the fraction of weight on the tow vehicle. With a regular boat or landscape trailer, tongue weight is only 10% - 15% of gross trailer weight. But with a semi trailer, I think tongue weight is probably something like 40% or greater.
   / Share Pics of People Hauling or Towing Something Wrong #20,574
No, that's not quite how it works. A semi trailer puts a portion of its weight, loaded or not, on the tow vehicle. That's the whole reason its named "semi trailer".
A pull trailer supports its own weight, and load, so it doesn't need a jack on the tongue. Okay, con gears (used to convert semi trailers to pull trailers do have jacks since they're heavy).
Below are two examples of typical semi trailers.
And here is an example of two pull trailers. Unusual ones, but pull trailers nevertheless, with steering front axles.
Come to think of it, the really simple way to tell a semi trailer from a pull trailer is if it has a steerable front axle or not. If it doesn't, it's a semi trailer.
   / Share Pics of People Hauling or Towing Something Wrong #20,575
I've never dug into the actual code on this, but looking at the resulting numbers, it appears to me the ratings are typically limited by tongue weight. Put more clearly, it seems the motive and stopping power of the most-heavily-configured 1/2 ton trucks is greater than its ability to carry tongue weight. And by "most-heavily-configured", I mean those with the largest engine/trans/rear option for their class, and sold with a tow package.
The reason I say this is that, if you look right down the line of ratings, excluding those limited by low-ratio rear diffs and small engines, the tow rating is always exactly 10x the tongue weight rating of the vehicle.
This is equally bogus, because it assumes the "ideal trailer", loaded to within a pound of the minimally-acceptable 10% tongue weight. That's not a practical assumption or safety margin, for anyone placing various loads on most trailers.
Max weight limits on a 1/2 ton truck are also figured with a properly set up weight distribution hitch.
My Sierra 1500 is rated for 9,500lbs. But I wouldn't want to pull anything over my landscape trailer with a 7000lb gvw without a weight distribution hitch.
   / Share Pics of People Hauling or Towing Something Wrong #20,578
And here is an example of two pull trailers. Unusual ones, but pull trailers nevertheless, with steering front axles.View attachment 883315
So, you’re saying a landscape trailer is a “semi trailer”?
   / Share Pics of People Hauling or Towing Something Wrong #20,579
I think he is saying “everyone has their own opinion.” Because I think he is nuts not wanting to tow anything with a 1/2 ton truck. But that is just my opinion. 😏
   / Share Pics of People Hauling or Towing Something Wrong #20,580
So the guy hauling the box in the trunk is super safe. Either the stretch wrap or a guy in the trunk holding it, but both, that is just overkill. ;)
Doug in SW IA
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
John Deere 7130 (A53314)
John Deere 7130...
John Deere 3025E (A53317)
John Deere 3025E...
2013 Cummins ISL G 300 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2013 Cummins ISL G...
