grease in a rotary cutter gear box?
   / grease in a rotary cutter gear box? #71
I would do an online search for that name and number
Didn't have a name to search on and a number is meaningless to google... but... turns out the "via Guido Rosse 10..." is an address that Google maps can find in Italy and street view shows me Comer Industries. Turns out they make tractor and heavy machinery shafts and gearboxes and other stuff... but nothing like my post hole digger gearbox. I suspect they no longer make that particular product.
Granger seems to have seals with about the right dimensions. I am going to use regular grease on the bottom and then fill it with 2 bottles of 00 Grease I picked up today from TSC. Get my holes dug before messing with the seal. Now that I know how this is put together I can pull the seal during the winter and worry about running back and forth to find the right size when I don't need it.
Lesson learned - check the sheer pins first. Just because it turns under no or little load but slips when digging does not mean the gears broke teeth.... it means the sheer bolts have jagged edges and are catching a little. Sadly, slip clutches are expensive so replacing the basic setup is going to wait, though it may be necessary given that I now have a more powerful tractor (RK37HC).
   / grease in a rotary cutter gear box? #72
Search numerous different combinations,....like Italy 3ph auger post hole digger. Be creative.
Can you contact the party you bought it from?
If all this fails, you will have to take the seal out and try to find a match with other brand of augers. It will be a time consuming search in person with the seal in hand.
Contact Comer Industries and ask them.
   / grease in a rotary cutter gear box? #73
Can you get some gasket material and with a ball peen hammer make one?
willy
   / grease in a rotary cutter gear box? #74
The place I bought it from is long gone. I am going to try the grease rout for now and make the seal search a winter project. I think Granger may have a match.
I've also wondered about using one of those "stop oil leak" products they sell for cars but I think it would only be a temporary solution.
I found you also have to consider the thickness of the seal!!!! This is fun reading: https://www.parker.com/content/dam/Parker-com/Literature/Engineered-Polymer-Systems/5350.pdf
   / grease in a rotary cutter gear box? #75
willy
That is way beyond my skill set, though an interesting idea if nothing else works. They use packing on boat propeller shafts, but it has to be adjusted regularly and this does not have that option.
   / grease in a rotary cutter gear box? #76
I have a leaky Howse finish mower that I have changed the bottom seal 3x now.
This time Im putting the corn head grease in the gear box, Im tired of fussing with it.
   / grease in a rotary cutter gear box? #77
Did you check to see if the bottom bearing isn't going out? That would make it eat seals.
SR
   / grease in a rotary cutter gear box? #78
Rob, I will check that out first and see if its the bearing, before I put the grease in,
Thanks for the reminder!
   / grease in a rotary cutter gear box? #79
I have used "corn head" grease or a blend of grease and gear lube in old gearboxs for years when they had minor leaks. Some got repaired after the season of use some have been working that way for decades.
   / grease in a rotary cutter gear box? #80
Some seals have the dimensions on them which allows a search by those dimensions. Had one rotary seal to go out on an old cutter that I was able to match by reading user comments on Amazon. Hydraulic shops are also pretty good at measuring old seals.
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
Sterling 9500 (A55315)
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
