LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,236
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I am becoming an expert in retirement.
I am finding myself doing quite well at that.Never put off 'til tomorrow what you can do the next day.![]()
Then I'll get days like the last couple my Nephew on the farm has had a run of bad luck with equipment, his bat wing mower blew a u joint yoke on the shaft through the wing gear box, his JD round baler broke the big tube that controls the belt tension and bale tightness.
They got things apart with just a small amount of help by me and a bunch of parts chasing, the brush hog shaft was close to $500 to buy, found the correct yoke after cutting the old yoke off the shaft, ended up with a new old stock for $45 instead of $70-$90 for a new 1 1/2" round bore yoke for 35 series u joint which should be here in a few days. Then we will weld that on the old shaft. Did a run this afternoon to pickup the new friction disc's for the slip clutchs on the bat wing.
Then spent some time yesterday looking a piece of tubing or pipe to slip fit inside the JD tube got a piece of sch 80 3" pipe coming for that and then this evening I just ordered a foot of 4" OD 1/4" tubing to replace the broken end of the tube that we are going to sleeving internally with the pipe.
Now my stuff I just keep putting off, should mow the lawn but it's not to bad yet, need to get the sprayer out to spray weeds but I need to unload the sxs to put it in. And should order a few loads of gravel for the driveway, but it can wait a bit.
SimpliPhi 3.8
