Crop Dusting share your picture and stories.
   / Crop Dusting share your picture and stories. #21
This past February our local cropduster was testing some new equipment:
   / Crop Dusting share your picture and stories. #22
Wife and I were driving down a local narrow county road. A crop duster was doing the edge of the field on the right, and flew almost directly at us. So I rolled up the windows and turned off the vents. Sure enough, about 3-4 seconds after he passed, the car got misted with droplets of who knows what? We washed the windshield, and continued on our way. Hosed the car off when we got home.
   / Crop Dusting share your picture and stories. #23
We lived in the country, next to a wheat field when I was in high school. One day, they were spraying the wheat for green bugs; very close to our house. They were probably using Parathion; which is what they used in those days.
I saw our baby chicks eating the disabled green bugs in our yard; the whole bunch were dead in a few hours.
   / Crop Dusting share your picture and stories. #24
I have a friend that has given up gardening in his back yard due to the crop dusters... everything wilts and dies within days after the plane goes by.
   / Crop Dusting share your picture and stories. #25
Not that it helps your friend particularly, but the adjacent farmer is liable for overspray in many areas. I'm not sure the few dollars would be worth the neighborly ill will to me, but I certainly wouldn't be putting in backyard veggies for sure.
@2LaneCruzer That's quite the story. The sodium chlorate would probably have been used as a desiccant, to defoliate and dry the plants out for harvest. They still use it today (defoliate-750).
All the best,
Peter
   / Crop Dusting share your picture and stories. #26
This time of year - the Forrest Service and several local crop dusters are flying for fire suppression. Some are turbo Air Tractors - 802 AT.
The really impressive one is the converted commercial passenger jet with the bright red fire retardant.
Last year I let the Forrest Service dip water out of my little lake. There were four choppers. Suppressing a fire - real close. It was exciting to watch. Like a small swarm of bees.
   / Crop Dusting share your picture and stories. #27
All the best,
Peter
As I recall, it was the per chlorate version, the same that is used in solid rocket fuel. There was a huge factory in Henderson Nevada that burned to the ground when they suffered a natural gas line rupture. Had a worker tell me he got it on his gloves in the wet state; it later dried, and when he went to take them off, they burst into flame.
Edit...guess you were right, it was the chlorate version. We eventually developed a formulation that was safe to use; it was called Tumbleaf.
   / Crop Dusting share your picture and stories. #28
Those guys helped save my place from a wildfire a few years ago.
When the fire came roaring over the mountain a few minutes later that red band of retardant stopped the fire right there:
   / Crop Dusting share your picture and stories. #29
The orchard I worked in used to hire a spray plane in spring, when it was too wet to use the tractor. I've seen him come in so low he'd be breaking water sprouts off with his axle. He'd come over the cold storage building, and lift the tail up to keep from hitting it.
During the same time period we had a massive outbreak of spruce budworm, which was devastating the softwood forests so every spring there was a massive spray program. You'd be driving down the interstate and see a convoy of planes flying in formation at treetop level, heading back to the airport.
   / Crop Dusting share your picture and stories. #30
No pictures but had drones doing fields behind my house and plane doing fields to east and west. Watched the two drones land and take off from trailer that had generator and chem tank. Didn’t time but would estimate around 8 - 10 minutes to spray a load and 1 - 2 minutes to reload chem and swap battery.
From reading I have done drones excel for small odd shaped fields or areas with lots of terrain changes and obstacles like trees, buildings, power lines etc. a big field around here is 120 - 160 acres and most have trees and power lines around them.
EZ-GO Freedom SE Electric Golf Cart (A57149)
EZ-GO Freedom SE...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
