WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 12,382
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
I have nearly zero experience with livestock and pastures, but I do take large-scale lawn and turf care to the level of most golf course groundskeepers, and so I know a thing or two about growing grass.We are actively purchasing a new property with a 1 acre livestock enclosure, that will get expanded over time, probably into 3-1 acre paddocks. The existing is nothing but sand, with some mixed in scrub oaks, and a few pine trees. So, the way I see it, I will have an opportunity to have no livestock for a period, and try to get some grass going in there. The question really is; for others dealing with sandy soils, and grossly overgrazed pasture;
1) benign neglect; would the existing seed bed, with the existing manure and urine and scattered hay; is just plain rest the best option?
2) take the opportunity to re level, remove stumps and trash trees, and then over seed?
3) just unroll hay, and out it into service?
I would start with a soil test, or even two. These are cheap, usually only $15'ish at your local turf pro shop. Grab a 1 pint container (eg. large yogurt or similar), and a bulb planter. Pull some plugs, 2" - 4" deep, and shake a few crumbs of soil off each into your container. Pick out any grass or other foreign matter. Repeat this in a dozen spots around your pasture. You'll cap and shake this container to mix it all together, and get a good "average soil" sample for your pasture.
If you have two very different soil conditions (eg. a wet area and a dry area, or a shady area versus a sunny area), it can pay to do two different samples, we actually sometimes do this for the tree covered versus exposed areas of our large lawn.
When you drop off the sample, explain your goal for the area, and the soil analysis folks will work up a fertilizer and pH correction plan to meet your goal. Fertilizer is not cheap, and even more importantly, it wastes your time applying it if it's the wrong mix. The soil analysis will ensure you're spending your time and money on the right product for your goals, versus wasting both. I can help you with adjusting your fertilization plan to meet their targets, which are usually just an annual total target.
We collect a soil sample every year in mid February, so we are ready to start with our fertilization plan in March. I spend a good bit of time and money on fertilizer and seed, and want to be sure I'm not wasting any of it. If nothing else, you want to be sure your pH is corrected, as all the fertilizer and seed in the world will be wasted, if pH is not correct. And pH is about the cheapest thing in the world to correct, versus the cost of seed and fertilizer.
