Sharpened My Peruzzo Ditch and Bank Mower Today
/ Sharpened My Peruzzo Ditch and Bank Mower Today #1
TerryR
Boone, NC
JD 870
For the second time in he four years I've had it, I sharpened the hammer blades on my Peruzzo ditch and bank flail mower today. I hoped it might improve the cut a bit, and/or reduce the power requirement. If it did, it was only a small amount on either.
I'm not at all sure ordinary wear required sharpening. Some of the hammers were pretty beat up from when I was learning to set it up. I set it petty low trying to improve the poor cut quality, and managed to mow quite a few rocks (I found that wasn't the solution, which was removing the front guard). The blades are good, but no match for football-sized rocks embedded in the ground. I didn't get them all that cleaned up last time I sharpened them, but did better today.
Some here have advised removing the blades and sharpening them on a wet grinder. Good in theory, so I tried that last time. After getting modest success on 2 or 3 blades in an hour, it was clear that was never going to work. So I figured out I can hold the blades in place with a couple of sticks and some bar clamps and do a better job much quicker with an angle grinder:
Did the whole thing in maybe an hour, and did get most of the dings from mowing rocks out.
/ Sharpened My Peruzzo Ditch and Bank Mower Today #2
Old thread, but thanks for posting the pic. I was looking for more efficient ideas.
This will work for me.
/ Sharpened My Peruzzo Ditch and Bank Mower Today #3
Great method. When I need to sharpen my hammer blades I'll try it. I have those EXACT extended clamps, right down to the color.
You're welcome. The clamps not only hold the blades, but are long enough to keep the rotor from turning as you use the grinder.
/ Sharpened My Peruzzo Ditch and Bank Mower Today #5
This exactly! I've got wood clamps galore. And my rotor is free spinning, this one pic solved more than one problem. Nice solution.
Btw, did your flail initially have a scraper bar behind the roller? (or maybe it's there and I can't see it)
I ask because when mowing tank banks or fish ponds, sometimes my scraper bar gets absolutely packed with mud grass combo. I try to keep the end out of the water to prevent washing out the grease etc but
sometimes an edge will be washed out or dig into a pile of pond mud. Anyway, it takes a big ass flat head
screw driver to pry it out...even when still damp. (tried a jet nozzle too).
No, mine does not have a scraper for the roller. It sometimes collects a little mud, but not enough to be troubling. But then I don't get near water like you do.
/ Sharpened My Peruzzo Ditch and Bank Mower Today #7
Good to know. Thanks.
/ Sharpened My Peruzzo Ditch and Bank Mower Today #8
Do you guys ever worry about unbalancing the unit when grinding the blades/hammers?
/ Sharpened My Peruzzo Ditch and Bank Mower Today #9
TerryR - did the John Deere help you with your hydraulic system problem?
What happended with your hydraulic system?
Was the issue with your mules pressure relief or the relief valve on the
flail shredder?
Hllo Oosik,
If a single hammer knife is broken that is the time when the flail shredder
rotor becomes unbalanced and the broken hammer must be replaced before
any damage can occur to the flail shredder/flail mower rotor bearings.
With a hammer knife only the top edge is sharpened. When I last sharpened
my flail mower knives I used my WEN wet well grinder to sharpen the cutting
edge as it is a cool low speed grinding method that does not destroy the temper
of the knife.
/ Sharpened My Peruzzo Ditch and Bank Mower Today #10
Hey Leonz - thanks for the explanation. That can be a really lot of sharpening on some of those flails.
SANY SY225C9C5KL EXCAVATOR (A59823)
SANY SY225C9C5KL...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
John Deere 270A (A60462)
John Deere 270A...
Deere 331G (A53317)
Deere 331G (A53317)
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
