Maschio Birba 155 review
   / Maschio Birba 155 review #11
If you do sharpen them, use a hand file wet or a slow speed water bath grinder as you will lose the temper in the casting and they will become more brittle and ruin them.
   / Maschio Birba 155 review #12
Thanks for your answer - BJ. I can see how it would make getting your hands in there with the U-joint to make connection - difficult.
My "lawns" are really mowed meadows. A perfect cut is never required. In my case - it's green and won't burn in case of an approaching fire. That's what really counts. I want to cut back the Buck brush - it will burn.
Another option would be to have it mulched down to the ground level to get rid of as much material as possible and then spray to keep it from resprouting.
Whoops! I already sharpened them with angle grinder. Next time, I'll use a file.
   / Maschio Birba 155 review #16
You could try it I guess, but I would hate to see you lose a set of knives ;0
Wen is offering a slow speed wet well grinder on amazon for $137.22 plus tax and shipping.
   / Maschio Birba 155 review #17
I'm
It has a round housing around the PTO connection. My bush hog has a hinged door that is easier to get to. But this one's not too bad.
I think the manual says it will handle up to .8" brush. So that should be ok.View attachment 880709
I have a dedicated driveshaft that I leave connected to my Maschio flail. That way, I just connect it to the tractor PTO, which has a flip up lid.
   / Maschio Birba 155 review #18
I have a "trick" for connecting the PTO. I hold the PTO shaft up with a bungee chord. That way I'm not having to hold up the weight while also trying to make connection. Every little bit helps.
   / Maschio Birba 155 review #19
2013 MACK CHU613 BOBTAIL VACUUM TRUCK (A58214)
2013 MACK CHU613...
2006 Mac 35ft Tri-Axle Dump Trailer (A56858)
2006 Mac 35ft...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
LANDPRIDE 5' ROTARY MOWER (A58375)
LANDPRIDE 5'...
2021 New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
2021 New Holland...
