Help me pick a tractor (25-45 HP)
   / Help me pick a tractor (25-45 HP) #111
I just going to say it quickly as well as correctly. Get the biggest one
   / Help me pick a tractor (25-45 HP) #112
then go 1 size up
   / Help me pick a tractor (25-45 HP) #113
The vast majority of Tier IV tractors between 25 and 75hp have no problems with their emissions systems. There's been a few bad models like the Kubota B3350 and some makes like LS where some units seem to do regens really often but mostly they work fine.
Operating in cold weather and idling a lot can make a DPF based system need to regen more often.
Below 75hp no one uses DEF like in pickup trucks, so that's one system that won't be causing problems.
JD Green tractors use DEF Fluid for anything OVER 25 HP.....
   / Help me pick a tractor (25-45 HP) #116
DEF doesn't come in to play until you exceed right around 75 hp.
No one uses DEF in anything under 75 hp.
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
Terms and Conditions (A55272)
Terms and...
LINCOLN PUSHMOWER (A58374)
LINCOLN PUSHMOWER...
LOT OF PIGEON HOLE CABINETS (A52708)
LOT OF PIGEON HOLE...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
