Where can I get these 40 amp fuses?
   / Where can I get these 40 amp fuses?
Here is the replacement part info.
   / Where can I get these 40 amp fuses? #12
I got in a hurry while trying to sell my tractor a few years ago and it wouldn't start due to dead battery. Swapped it out while the potential buyer was standing there and wasn't paying close enough attention and got battery terminals switched and blew that main fuse.
It happens.
   / Where can I get these 40 amp fuses? #16
sun that was 14 years old
pretty sure sun is older than 14.
anywhoo as you now know the slow blow fuses are the same as in whatever vehicle you drive
Fixed it so I dont sound like I was having a mini stroke.
   / Where can I get these 40 amp fuses? #19
   / Where can I get these 40 amp fuses? #20
Ha - just read your post about hooking up the battery wrong, and I did the same thing on my wife's New Holland TZ25da - as the battery lost power and needed to be changed.....well, it turns out that after changing the battery that the alternator was not charging, so after having problems finding the exact replacement alternator - I replaced the internal regulator on the alternator and all good now... So, the first problem was the 40A slow blow fuse and after locating it hidden in some wiring harness under the engine I found the special fuse at Advanced Auto Parts - cost around $8, and it worked to get the tractor running. I picked up a spare on eBay for a few bucks too....
BARBED WIRE (A58214)
SKID STEER ATTACHMENT RAKE (A58216)
SKID STEER...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2016 Hyundai Sonata (A56859)
2016 Hyundai...
