Ferguson TO-30 pos or neg ground?
   / Ferguson TO-30 pos or neg ground? #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
I just bought a decent TO-30. The specs say that is has a positive ground off the 6 volt battery. The tractor I just bought has negative gounding. The engine starts well. Is this possible?
   / Ferguson TO-30 pos or neg ground? #2
I guess someone could have converted it though I'm not sure why they would go to that trouble and not make it a 12VDC system as well.
Very true. But am I right that with the polarity reversed it will not start?
   / Ferguson TO-30 pos or neg ground? #4
are you looking to convert BACK to positive ground to keep in specs?
cause your first post specifically said it starts well.
been years since I worked a + grd but IIRC biggest issue was alternator/generator.
   / Ferguson TO-30 pos or neg ground? #5
Tractor doesn't care if it is positive or negative ground the only component that will care is the charging system. If it still has a generator then you can polarize it for positive ground, if it has an alternator then it probably has been converted to 12v and it needs to stay negative ground
   / Ferguson TO-30 pos or neg ground? #6
remembering more.
SO MUCH THIS!
DTLM.
Diode Trio Lives Matter.
you said it starts, step away from the precipice buddy.
remembering more.
SO MUCH THIS!
DTLM.
As long as it runs, I don't care what the ground is and won't change anything. I was just very surprised to see the negative ground when the specs say the tractor is positive. Could this be a reason for the ammeter to barely move after starting? Also if I reverse the battery to negative ground might something get damaged? Many thanks to you all and please answer these last two questions.
I need to add, it appears to have an original generator, no alternator.
   / Ferguson TO-30 pos or neg ground? #10
Nothing bad happens, make the switch to Neg ground and observe the ammeter action. You might have to re-polarize the generator, which is easy-pezy.
49205 (A55788)
49205 (A55788)
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
