JethroB
- Joined
- May 19, 2020
- Messages
- 2,346
- Location
- Really Deep Southeast
- Tractor
- Kubota L5460 HSTC Cab, MF 135 Diesel
Great find
I see that yours has the cylinder lock valves on the side shift cylinder, mine has them on the tilt cylinder which I thought was a strange location when the manual talks about using float on the tilt which will not work on a lock ported cylinder.Found this 10 month old Peruzzo Fox Cross 1600 on marketplace a few days ago. Reached out to the seller to see what the story was. Apparently he ran it for two passes around his pond and decided he wasnāt comfortable being that close to the bank due to how steep it was. Itās been parked in the bushes ever since.
Drove an hour to take a look at it. As soon as I saw it I made him an offer and he accepted. Other than a couple of small paint scuffs itās a brand new mower. Hammers look perfect.
Iāll have to wait a bit before Iāll be able to run it. I need to get the rear hydraulics on order from Yanmar and get them installed but Iām happy to have it nonetheless. Between this and the Land Pride FDR3690 then I just picked up I should be able to handle everything around this property.
Can you enlighten me on the lock valve? I was too hot and tired to go through the operators manual this evening. Planned on going through it tomorrow.I see that yours has the cylinder lock valves on the side shift cylinder, mine has them on the tilt cylinder which I thought was a strange location when the manual talks about using float on the tilt which will not work on a lock ported cylinder.
Also I see the tilt cylinder is using the slotted mount which allows considerable "float" to that cylinder and has the slotted position for your top link to allow the rear roller to float the top link.
Often a lock valve is used to hold a cylinder in place even when a valve has some leakdown, it requires pressure to open and allow fluid flow. They are often seen on hydraulic top links to prevent uncontrolled extension.Can you enlighten me on the lock valve? I was too hot and tired to go through the operators manual this evening. Planned on going through it tomorrow.
You have a simple double acting check valve on one port that holds in one direction and releases by using the valve on the tractor to push oil flow in the other direction.Can you enlighten me on the lock valve? I was too hot and tired to go through the operators manual this evening. Planned on going through it tomorrow.
A crossover relief valve needs 2 equal cylinder volumes to work. A pair of single acting cylinders for angle on a snow plow is a common setup. A single double acting cylinder will not work with a crossover relief valve. The rod end has less volume than the cylinder end. So if the valve opens there would be pressure spikes if it compresses, but no protective motion. If it gets extended, there may be some protective motion.Often a lock valve is used to hold a cylinder in place even when a valve has some leakdown, it requires pressure to open and allow fluid flow. They are often seen on hydraulic top links to prevent uncontrolled extension.
Hydraulic | LOCK VALVE | Doering Company
It is also possible that the valve arrangement on your offset cylinder is a cross over relief to allow the offset cylinder to relief if the mower snags on something
Greetings all -- First time poster here, and first time flail mower owner. I am looking for some advice on basic setup and mowing technique. I have a Kubota L4060 and Vrisimo Minimax 60" flail mower. I am looking to mow 10 acres of dense 3ft grass with some light brush mixed in on occasion.
On my initial mowing attempts, I quickly caused the main belt to smoke. My speed was between 1-2 km/h. Grass as mentioned above and moderately wet. I am thinking that the ways to manage this are, cut height and tractor speed. I was mowing in a snaking line, taking full width passes.
Given my circumstances what is the desired cut height? My intuition is that a higher cut height would cause less stress on the mower; and that driving slower would provide less stress on the mower. Yet, I have read here and elsewhere that having a 2" or lower cut height can be optimal given how these mowers operate.
Regarding cut height: I have read the owner's manual, and it seems to me that there are three points of adjustment. 1) roller height adjustment ie, "back gauge roll adjustment", 2) top link arm length adjustment, 3) actually raising or lowering the three point hitch. Is this correct? It seems to me that the top link arm length adjustment makes that roller a pivot point causing the mower to sit at a shallow angle.
In general is it best to mow in rows or spirals? Should I take full or half passes? Should I make multiple passes?
I will continue to read this thread looking for answers, but thought I would post here as well.
Much obliged to any advice.
@leonz Thank you for your thoughtful reply and advice.
I will setup the cut height as you advised. The trickiest but will be finding a true flat spot as I live on a hillside!
I have the HST model, with a ROPS. I was thinking of putting on some music while I mow, but I wanted to better understand the belt burning issues first; the first indication of slippage is sound so I didn't want to obscure the warning signals.
The dealer did not mount the mower, I did. They did mention that I may have to cut down the PTO shaft length, but it does not seem too long to me, and installed without incident. I have eliminated the sway using the turnbuckles and have it fairly centered.
The unit shipped with scoop knives. Given that I have light brush intermixed with the grass should I consider the industrial or dethatcher knives?
What causes the v-belt to burn and smoke? How do I prevent this?
How do I know when the belt needs to be replaced? Are replacements available from 3rd parties or must I order from dealer or manufacturer? I will purchase a gauge as advised; how do I know what the optimal tension is?
Should I grease the rear roller bearings or the V belt idler bearing after every use?
I have noticed that grass gets wound up on the roller where it mounts to the frame of the mower on both sides. The grass is packed tight enough where I need pliers to extract. Is this something I should keep after?
Thanks again.
Max
The Ford 917 calls for a banded belt and it works good as well as last for a long time.Yep, that is the lowest roller position which will yield the tallest cut. With the top link lengthen out to set the machine fairly level fore and aft. You can then vary the cutting height by lengthening the top link (taller stubble) or shortening a bit (shorter stubble).
When replacing multiple V belts as leonz has mentioned you should get matched bet sets or if your pulleys can fit them banded belts will work better.
They are available in most sizes and configurations, 2,3,4,or 5 belts in one
