GR2110 Glide Steer Cable Adjustment
/ GR2110 Glide Steer Cable Adjustment #2
What is "glide steer" exactly?
Glide steer is a system that disengages the inside rear tire during turns. The tractor is full time 4 wheel drive. Cables attached to the steering knuckles move levers at the rear axle to disengage a clutch for whichever wheel is on the inside of a turn.
The tractor will almost pivot on that inside rear tire during a turn.
/ GR2110 Glide Steer Cable Adjustment #4
Pretty cool almost like a 0 turn then.
Do you have the owners and service manuals ?
I found a service manual online but it isn’t entirely clear on the adjustment process.
I think I did manage to get the cables adjusted correctly though after reading the manual’s description of how the system works.
New/Unused 110V Diesel Pump with 50ft Hose (A65583)
New/Unused 110V...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
J.I. Case 2090 Tractor (A66285)
J.I. Case 2090...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
2014 Frontier BB2060 Box Blade (A65640)
2014 Frontier...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
