Good morning!!!!
   / Good morning!!!! #193,391
Got soaker hose on the indeterminate tomatoes hooked up and set the timer for 15 minutes.
Shortly after that it clouded up as I started weeding the hosta ring around the oak tree.
Surprisingly the temps seemed pretty pleasant.
Probably 15 minutes later I noticed the wind coming and some raindrops starting to fall.
Within a couple of minutes that turned into a downpour so I came on in.
Probably won’t last very long.
Woman over at relatives picking up leftovers from yesterday.
Squeak taking advantage and getting some lap time.
   / Good morning!!!! #193,392
electrical malfunction in rv
every time I plugged it into garage outlet popped gfci in garage.
unplugged from rv, fine all the way to end of cord, lights on, surge protector has three
green lights. But when I put power on connected to rv, breaker pops immediately.
I have only one gfci in rv. I set it and unset it and same breaker trip no matter what position of gfci.
my concern is the converter, what changes AC to DC. Will take another look at that later, checked to make sure all
circuit breakers were fine, and they were, and no strange smells.
I washed the far side of rv this morning, hmmmm, maybe I should go blow air in the outside 110v receptacle.
there should be very little load on start up, only the rv battery charger. So sounds like a short?
   / Good morning!!!! #193,393
some gfci's go bad. Do you know how many amps the rv is supposed to be pulling?
If your circuit can handle 20 amps, I've put these in a situation that kept popping a regular gfci.
https://www.lowes.com/pd/Eaton-20-A...Residential-Decorator-Outlet-White/5014437327
   / Good morning!!!! #193,394
good morning, 72 going to 95 today still no rain
More string trimming yesterday and watering. May start to mow the large field today. Will see what wife is up to. she may have other plans
Have a kid in hospital now for several weeks. She needs heart surgery but is not able to due to an infection
Prayers for your loved one, Frits.
   / Good morning!!!! #193,395
Drip irrigation about halfway through.....
Was sitting on the front porch when, all of a sudden, birds were flying every which way, scrambling for cover.....
An hour and a half later, I went to the backyard to start drip there.... this is what I saw:
The remnants of a ring necked dove.....
Wifey saw a hawk earlier sitting up high in a tree. I guess they have chicks to feed too! Only remnant besides the feathers was one foot.....
I'm still feeling good, actually hungry now. Going to make eggs, bacon, and hash browns for an early "Linner"... too late for "brunch".
98° out already, 3 degrees above forecast. Can definitely feel the strength of the sun at this elevation. At least we don't have too much humidity at 20% today. A few storms building in the distance. Maybe we can get one....
   / Good morning!!!! #193,398
thanks
I'm going to swap it out tomorrow but not sure that is it.
hooked up my 110V Makita air compressor and it ran off that garage outlet fine.
I think something in rv is tripping garage breaker.
when I put on generator all the ac came on in rv; this seems to be an issue with shore power.
more experimenting needed but happy to swap out gfci
   / Good morning!!!! #193,400
thanks
2 GFI’s in series usually does not work.
Should say that a little different.
1 GFI feeding another GFI does not always work.
Portable Restroom (A54865)
Portable Restroom...
MASSEY FERGUSON SEAT (A58374)
MASSEY FERGUSON...
2018 Chevrolet Silverado (A56858)
2018 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JRB 54" QUICK ATTACH HANG ON WHEEL LOADER FORKS (A52709)
JRB 54" QUICK...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
