Cedar Porch Ceiling
/ Cedar Porch Ceiling #1
Duds13
Charlton, NY
Kioti CK2610, Kubota BX 2200
I am having my porch remodeled and will be putting up tongue and groove cedar on the ceiling. Wondering if I should leave the cedar untreated or if I should at least seal it. It's protected from the elements so I'm wondering if it needs anything at all. Thinking about putting a clear Ready Seal on it though. Any recommendations?
/ Cedar Porch Ceiling #3
Before Covid, I tore down my small back porch and started building a bigger back porch that's 16x24. My ceiling is 8 foot long T&G Western Red Cedar that cost $14 each at Lowes. I bought enough to get started, but not enough to do half of the ceiling.
After the Lockdown, it disappeared for a year. I got lucky and found some that had been returned to McCoys that was 10 feet long with damaged ends for $14 each. That got me just over halfway.
When it showed back up on the shelves at Lowes, it was $34!!!
I slowly bought a couple at a time, until I had enough. It was stupid expensive, but I had already committed to it and there isn't anything out there that I liked better.
Before installing each board, I set it on a saw horse and soaked it with Sherwin Williams Super Deck Exterior Oil Based Transparent stain. To me, it makes a very attractive wood into something of extreme beauty. I couldn't imagine not using it, the difference is night and day better!!!
I install each board with a stapler, and when I get to where a light is going to go, I install the board, drill the wood to fit the light, and install the light. Then I move on. I did the same with my two ceiling fans. When I was almost done, I realized that I wanted a couple more lights in my soffit, so I had to play that game of getting 14/2 romex to go about 12 feet to where it needed to be, in a small space.
Be sure to have a solid plan on lighting, and to have everything in place before you install your wood. I went with 3 inch LED can lights, which we really like.
First Year
Second Year
Forth Year
/ Cedar Porch Ceiling #4
I'm thinking of doing my porch roof, but probably tongue and groove pine.
/ Cedar Porch Ceiling #6
I priced 8”x 16 ft pine t&g at $24 each, I’ll need 50 for the porch. Existing ceiling is 1/4” painted plywood with no batons, a quick cover when I built and it stayed. will run new long ways, porch rafters 24” oc. . Will have to lower siding j channel some, thinking of removing wall lights and using LED ceiling lights. Even debating new hardi siding on front of house, but don’t know how that would look with siding on the rest. Originally was going to brick the front, that got cut due to price.
/ Cedar Porch Ceiling #7
I went with 8 foot T&G on my ceiling because it was so much easier to work with by myself, and it's easier to find 8 foot long boards that are straight, then it is to find longer ones. Even at 8 feet, some of them had to be persuaded with a rubber mallet to get them into position.
Always stain or seal them before installing them.
/ Cedar Porch Ceiling #8
I have a Pan Abode cedar timber house. 100% cedar - inside and outside.
I've tried a few different products on the outside. Behr log oil - polyurethane - InWood Semi-translucent oil stain.
BY FAR - the InWood oil stain is the very best. I see Eddie had good luck with an oil stain product also. It's been twenty years since I've had to recoat any outside surface on the house. Except the SW side that faces the afternoon sun. That side gets a new coat every ten years or so.
I'm sure there are many companies that make an oil stain product. I know that InWood comes in many different colors.
For goodness sake - do not use any kind of polyurethane product. It is like coating the cedar with Suran Wrap. Cedar breathes. Large bubbles will form on the cedar and will end up in humongous mess. I have direct experience with polyurethane on cedar.
The log oil yellowed after five or six years and proved to be an inferior product. At least for cedar.
This is the entrance to my house. I've put InWood semi-translucent oil stain on the outside of the house. I used their coffee color. This was last recoated 21 years ago. I really like the darker color as compared to the yellowie color of the natural cedar. All the darker shadows are from the morning sun shining thru the large pine trees.
/ Cedar Porch Ceiling #9
I'd seal it, both sides before installation. You'll never get another chance to seal the backside.
Agree. I did the same thing about 5 years ago on my porch ceiling, except I used spruce tongue and groove boards. I used the Thompson water seal with stain and treated both sides before installing. I know the ceiling doesn’t get direct moisture, but it is outside and exposed to humidity and such. Being on the ceiling, the OP would probably never have a rot problem with cedar, but sealing preserves the appearance from staining.
/ Cedar Porch Ceiling #10
If the ceiling makes a 90 deg angle for a wrap around, would you run a piece at the 45deg and run each side into it, or just run eachside in without a piece between them? does that make sense? Here’s a picture showing both ways
/ Cedar Porch Ceiling #11
I would run a piece between them.
/ Cedar Porch Ceiling #12
buckeyefarmer - it, more or less, depends upon the look you want to achieve. Done properly - either way would be fine.
First Year
Second Year
Forth Year
That looks fantastic Eddie. I found a local mill who had 8' cedar boards for $14 so I bought 50 of them. I ended up sealing them with Watco Exterior Wood sealer. I got the same look you have and I love it!
Couple photos. We are adding two more lights to the porch and will replace the one in the photo with a more rustic style light
/ Cedar Porch Ceiling #15
Good deal finding them for $14 each!!!! I miss the days when they where that much at Lowes.
The cedar is going to change the entire look of your porch.
Thank you! $14 a board saved me a lot of $$ for sure. It will definitely be a nice transformation. The posts are going to be wrapped with cedar and sealed with the same sealer. The original floor was pressure treated wood that was painted, so it was always peeling so we went with Timbertech Azek in the same color and a picture frame pattern. The color is close to the color of our barn and a brown floor would have been too much brown in my opinions with the brown windows and doors.
/ Cedar Porch Ceiling #17
Looks great. What are you going to do in front of the door?
Thank you. Not sure what you mean? For decoration? It's a step up into the house.
/ Cedar Porch Ceiling #19
Sorry. I assumed you where going to put a step or something in front of the door so it's not a tripping hazard, but I know that some people get used to not having the outside being the same height as the inside of a door.
No worries!! It's a regular step up and is pretty common in this area people are used to it.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
Informational Lot - Financing (A63688)
Informational Lot...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
