Rookie tractor buyer neds advice
/ Rookie tractor buyer neds advice #1
ChubbyButtNinja
none yet
Hi. I’m new to tractors but am getting close to buying one. I am a total rookie.
Situation: Have somewhat accidentally ended up with six acres to maintain. Was initially going to get a subcompact and rotary cutter, but have felt like I should try to redeem the land and not just stare at shorter weeds on it. The land is “flat” but there are a lot of bumps and small (3-4 foot) elevation changes that I will try to level out some. I have asthma and need a cab, but our needs seem modest for the six-acres property where we’re going to try to keep a smallish farm. We don’t know what crops we will plant - we are working with the UGA extension team to figure that out.
I have really liked Kioti and a big dealer gave me a quote on a CK2620 shipped to me. I've looked at and come close to buying used DK models. My local LS dealer has given me what seems like a great quote on the brand-new LS 226. I saw one dealer in Oklahoma has what seems to be a great deal on the TYM 4215 which I'm considering. I have gotten an okay quote on a Bobcat 2535 from a brand new dealer local to me but the attraction there is he's so local and we've done other business before so I trust him. I've visited a couple of JD dealers but their cab models are basically double my quote for the LS. Of course, I like the new tractor warranty but I'd be fine with a used tractor that has a good track record.
I feel like as a total rookie it could be smart to get something bigger and more stable than I need. I can pay cash or finance and am making that decision based on how big the cash discount is.
Budget is max around $40k out the door with my starter implements.
Would also be interested in two supplemental questions:
- What are the no brainer early attachments besides some kind of cutter and a box blade to help with the grading?
- Is a flail mower worth the upgrade over a rotary cutter, or put another way under what conditions would you splurge on the flail mower.
I'm very grateful for any help.
/ Rookie tractor buyer neds advice #2
When you buy a tractor, the dealer you buy from is just as important as the brand you buy.
I find it hard to compare tractors. They all seem pretty good these days.
Parts availability is important. When your tractor is broke down and you have to wait a month for parts......
I've owned an Iron Horse (Jinma) open station, no complaints
A Massey with after market cab, no complaints.
A Branson with dealer installed factory cab (no AC), no complaints.
Currently a TYM 65 hp with cab, no complaints. Well, a little one. It doesn't have a temp gauge for the engine. One of those things you don't even think to look for. Who builds a tractor without a temp gauge?
Attachments? You can never have enough.
/ Rookie tractor buyer neds advice #3
Iirc, that 4215 is a lot more machine than the others. The 42 HP version is apparently being phased out, but it is exactly the same as the other xx15 models except for the tuning.
Pallet Forks have been handy and are not too pricy.
I went with a ditch mower flail. It was about the same price as a good RC. The hydraulics allow for things an RC cannot do and the mower isn't as 'long', so it's more maneuverable. The RC length is a plus when using as a counter-balance for loader work.
/ Rookie tractor buyer neds advice #4
If it is for farm use, it can be sold sales tax-free, at least in Oklahoma and Kansas. Buying in OK might save you a lot of money. This is most likely true in other states, but I live in Kansas and buy in Oklahoma. Usually, the Tulsa and Coweta area has the best deals. The dealers are all used to writing off the sales tax if you state that it is farm-related.
As for flail mower vs. rotary, the flail gives a nice, clean cut—think of a golf course—especially if you have nothing but flat earth. But if you hit a rock, you start to replace blades in many cases. And they are not great at mowing larger underbrush, at least the ones I have seen.
Rotary mowers have just two huge blades with a stump/rock hopper hub if you have freshly cleared or rocky land. You will still hit the rock or stump with the blade, but they are designed to fold in, jump the obstacle, and start mowing again. The blades last an incredibly long time, but you will of course have to sharpen those if you smash into a lot of hard stuff. These are really good at clearing most anything your tractor can run over vegetation-wise.
I have a Ford 900, Kubota 2500 and a TYM 4215. For the money if all you are going to do is mow, and nothing else, a Ford 900 is cheap and so are parts and it has live PTO. There are aftermarket loaders and the 3 point attachments are everywhere. Every auction has 5- 10 it seems.
My Kubota is cheap to run fuel wise, has a front end loader and the diesel has never failed me. My only complaint is getting onto the dang thing takes acrobatic ability to fit my size 14 feet into the step and then cross over and get in the seat. Parts are getting cheaper, and can be hard to find if it is a cosmetic part (Headlight assembly for example).
And my most used is the TYM 4215, easier access, easier 3 point access and parts are not horribly expensive. I can call up Coweta and they have the parts to me next day in most cases, sometimes 2 days. But I only live 3 miles across the Kansas-OK border, so that may be a huge part of that.
Service is easier than the Kubota to find the engine for oil changes, etc.
Hope that helps some.
/ Rookie tractor buyer neds advice #5
I have a Branson 3515h and I really enjoy it, but sometimes I wish I had gotten either the 42 or 48 in the 15 series. If you can get a good deal on a 4215 I think it would be a great choice as you could run 6 ft implements on the back.
/ Rookie tractor buyer neds advice #6
I also run a flail mower on mine I feel it cuts better than my rotary cutter and chews up small saplings and brush better. If you do get a flail I would suggest get the hammers.
/ Rookie tractor buyer neds advice #8
I think a Kioti CK2620SE Cab would be a great choice for 6 acres. Comes standard with dual rear remotes so you can run an offset flail if you want one. Get the third function on the loader to operate a grapple.
/ Rookie tractor buyer neds advice #9
As far as implements, I recently got a ditch bank flail with hammer blades and it does a great job on small brush, saplings and tall weeds. It also does surprisingly well on my front field that's maintained as a lawn. The hydraulic offset let's me get into places that a rotary cutter just can't, or at least not without a lot of difficulty.
On edit: you don't mention a loader... I would never buy a tractor without a loader.
Happy shopping!
/ Rookie tractor buyer neds advice #10
All three Korean manufacturer’s make nice machines. I would try and compare similar models that have the most similar engines, ie 25hp TYM to the 25-26 Kioti and LS, or the 40hp models of each.
Happy shopping!
I assumed the loader was such a no brainer it wasn’t worth mentioning but you’re right to point that out.
All three Korean manufacturer’s make nice machines. I would try and compare similar models that have the most similar engines, ie 25hp TYM to the 25-26 Kioti and Tym, or the 40hp models of each.
I really have been focused on 25hp machines due to price and avoiding the regen. 40hp machines have only come in play when there’s a great deal.
For example, the TYM 4215 is considerably less than the Kioti 2620.
/ Rookie tractor buyer neds advice #13
What has worked for me was being patient, and buying an almost new one from an individual. Maybe Craigslist. Hey no bigger crooks on there that some dealers. Good luck friend
/ Rookie tractor buyer neds advice #14
The regen is a lot less scary with a TYM (formerly Kukje) engine. Even if you have a problem, the tractor will not go into limp mode. If you keep the rpms up, it will rarely even need to regen.
/ Rookie tractor buyer neds advice #15
Make a list of things you want to do. Then how often you will do them.
Some jobs are better done by a contractor or renting the right machine. People buy a backhoe and it sits for many months. And it is not a cheap attachment.
If you have asthma, putting 3 point attachments on and off will be taxing. Look into a quick hitch and make sure your attachments are compatible with it.
You have not provided enough information to make an informed suggestion on implements, and IMO you need to do more thinking about what size machine you buy.
A cab tractor without air conditioning will be a bad decision in most of the country. I need to run air even when it is only 70 degrees.
/ Rookie tractor buyer neds advice #16
Very few people have issues with Regen. I think it is a very overblown issue. Not saying it can’t be an issue, but not a common issue. Take LS for example. You hear about people have issues with the machine regenerating too often, but it is not that common and most people don’t have issues at all. The new MT2 series use Yanmar engines anyway and probabaly regen normally as much as any engine. That said, it is added complexity and cost to an engine, so if you don’t think you need it then yes, stay at 26hp or under.
The TYM 4215 model is being discontinued from what I hear. Probably a good time to get a deal on one. The tractor model itself is the same as any other 15 series and the 42hp engine isn’t going away, so no worries about getting a model with no support, it will have support for as long as any 15 series TYM model.
The new MT2 series LS are really nice also. Lots of upgrades on these new models. Don’t think you can go wrong with any of the three makes though and all are popular.
Besides the Korean makes, Massey and Yanmar make some really nice tractors this size that are quite a bit more affordable than John Deere and Kubota. Both are Japanese made.
/ Rookie tractor buyer neds advice #17
A little more advise, buy as big as you can afford now, and buy from a local dealer, especially being that this is your first tractor. If you were an experienced tractor operator and could work on your own equipment, I’d say buy from wherever, but you are a noob, so find a good local dealer and buy from them, even if it costs you more.
As far as implements, a decent set of pallet forks will get used all the time.
You mentioned working with Georgia Extension, so not sure where that is heading as for crops, but that could really dictate where you go with attachments. 6 acre wouldn’t be a hay farm, but could be all the ground you need for specialty vegetables or something on those lines. Give some more info and would be glad give some suggestions. Also, how clear is the 6 acres? If you have a lot of trees a grapple will always come in handy. If it is already cleared, you can probably get buy with the pallet forks for all your lifting needs.
/ Rookie tractor buyer neds advice #18
/ Rookie tractor buyer neds advice #19
When I bought my Deere 3033R the dealer suggested a 3 in 1 bucket. Looks and works like a regular bucket but also opens hydraulically to allow me to clamp down and lift things.
Great suggesting and once I put it on I've never used the old standard bucket.
/ Rookie tractor buyer neds advice #20
"Was initially going to get a subcompact and rotary cutter, but have felt like I should try to redeem the land and not just stare at shorter weeds on it." OP
you might be more detailed in what you consider "redeeming" the land, what that redeeming would involve. many have suggested in the forum that if extensive leveling, excavation is to be considered, sometimes it's more cost effective to hire the redemption out, then decide on an appropriate tractor.
if all you're considering is heavy brush hog work, then proceed as you are doing. in terms of rotary cutters, look to mid or heavy duty. certainly not a finish mower. consider 45-50 hp, L or MX series Kubota would be a good start. a 6' hog would be a good match.
regards, & welcome to the forum
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
(250) PALLET OF UNUSED SAFETY CONES (A60432)
(250) PALLET OF...
