Dead animal in pipe
   / Dead animal in pipe
Shoot them.
I've thought of this but the only realistic shot is down through a narrow opening in a metal grate, with concrete on the bottom.
I don't think the neighbors would be an issue with gunfire, but I might be with a ricochet.
Good idea but the only pipe opening is below grade in the side of a narrow irrigation ditch. (18" wide?)
Rigging a trap to that would be difficult and I'm concerned about crazed marmots if I pull the weighted down plywood barricade out. 😀
   / Dead animal in pipe #15
I'm not there to see what you mean exactly, so obviously I can't say for sure. From what you describe though, it sound like you could just stick the barrel through the grate and shoot them at close range. The bullet isn't going to ricochet if you hit them and unless the neighbors are right next to you they'll never hear it. A .22 bullet that travels a few feet or inches and then enters a soft body makes less noise than a hammer hitting a block of wood.
   / Dead animal in pipe #16
But if you kill them in the pipe you have to get the bodies out. The possibility of some maggot gagging mess looms very large. Find out what they love to eat, use that to get them out, and then send them off to their eternal reward.
   / Dead animal in pipe #18
Call roto-ruter, that's their name and away goes trouble down the drain. :)
them or some like them can walk a high pressure walking nozzle down the drain and flush them out.
it is done around here in field drainage tile plugged with corn stover.
   / Dead animal in pipe #19
I still don’t get why you can’t just drown them. Plug up the far end and fill it with water. They’ll run or float out the close end. Unless there’s something to the actual situation I haven’t envisioned
   / Dead animal in pipe #20
Not in my experience, maybe if using subsonic rounds.
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
New/Unused Mini Skid Steer Bucket Mixer (A57454)
New/Unused Mini...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
Great Dane Van Trailer (A56436)
Great Dane Van...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
