Massey Ferg GC1705 PTO Fubar
/ Massey Ferg GC1705 PTO Fubar #1
LisaOH
MARYSVILLE
GC1705
I learned an expensive lesson, the shaft connecting the brushhog to the PTO was apparently too long and when trying to move some dirt with brushhog attached, it resulted in the PTO going through the housing and hydraulic fluid everywhere. The guy that came out to try and repair said we would be better off buying a new tractor. If there was a way to seal off that big hole, could we still use the tractor to just pull a wagon and just not use the PTO or loader?
/ Massey Ferg GC1705 PTO Fubar #2
Sorry to learn this. Once I was backing up a brush hog and it started to raise up and climb a hill and I worried about this exact thing happening. fortunately I stopped.
Hope there is a way to salvage this!
/ Massey Ferg GC1705 PTO Fubar #3
You may consider fashioning a blocking plate to cover the rear opening where the PTO was removed. Using gasket sealer it should prevent leaks from the hydraulic reservoir. If your hydraulics are otherwise intact you may be able to use the tractor for pulling and use the loader.
Thank you, that is what I was hoping might be a possibility
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
PALLET OF BLACK FENDER FLARES (A60432)
PALLET OF BLACK...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Ingersoll Rand 175 S/A Towable Air Compressor (A59228)
Ingersoll Rand 175...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
