DJI Mini 4 Pro Drone questions
/ DJI Mini 4 Pro Drone questions #123
Really good advice and this makes a *huge* difference in playback. This, on its own, might fix everything.
Also, you can easily investigate your existing computer to see if it is capable of accepting additional RAM memory modules, or if it will accept higher capacity memory modules in place of what is there now. Your computer should tell you how much memory it has. If you look up by model number you can find what the maximum memory capacity is.
A fairly inexpensive memory upgrade for your computer might be all that you need to make a bid difference. In most cases it is as simple as removing the cover from the computer and snapping in a new or additional memory module.
Beware of two simple issues if you do this upgrade-- 1) purchase the correct memory for your specific computer, and 2) be careful with static electricity. Memory "chips" and modules are static electricity sensitive. Even walking across a carpet can create static electricity harmful to memory modules. You can easily look up some simple precautions to make sure your memory upgrade is a success. A real simple thing is make sure you are well grounded when opening a computer or memory module package.
memory is generally not the issue with 4k, if he opens task manager, he will prolly see his cpu maxed out.
/ DJI Mini 4 Pro Drone questions #124
Controller to drone connectivity requires line of sight. So make sure not to fly where you lose line of sight.
I sure didn't know that. Farthest I've allowed mine to venture was 2 miles, according to the screen readout. I wonder what would happen if one lets the drone just keep going away? Would someone (not me!) give that a test?
/ DJI Mini 4 Pro Drone questions #125
visual line of sight and rf line of sight are different things.
once the drone (dji at least) loses connection to the remote control. it initiates a "RTH" Return to home sequence and flies back to the home point. This is why its important to make sure the RTH point is locked to the correct point before venturing off and RTH altitude settings are correct.
/ DJI Mini 4 Pro Drone questions #126
Lots of YouTube videos that test this to watch. Most generally run out of battery before range. Spoiler alert, most are 4-5 miles for the max.
/ DJI Mini 4 Pro Drone questions #129
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A61307)
2019 Takeuchi TL8...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
