Aluminum car trailer vs steel
   / Aluminum car trailer vs steel #11
I wouldn't be afraid of an aluminum trailer at all, considering your application. 8 years ago I bought an Aluma Model 7816 all-aluminum trailer and it has held up perfectly despite being used mostly on washboardy dirt roads. It has thousands upon thousands of miles on it - I've towed a car on it to Texas from Nevada, and my Jeep all over the west coast and my side by side also. I've had to do NOTHING as far as repairs to it. I did paint it white because I preferred that to the aluminum color (deck is aluminum also); I also mounted a 4' high piece of plywood across the front because gravel off the towing vehicle's tires was messing up paint and glass on whatever was on the trailer. The fenders are quick and easy to remove in case the car doors don't clear.
That looks pretty solid! My uncle recently retired and looking to hit the road more often and bring their quad bike. His F250 got a new camper so he had ordered new tires and dually wheels, and will be looking for a new trailer next.
   / Aluminum car trailer vs steel #12
Me, I wouldn't ever consider an aluminum trailer for anything. More prone to cracking at the welds or severe stress points and when they do crack, they are hard to repair as they have to be very clean and not everyone can repair them. I say that as a welder for almost 50 years with both steel (majority) and aluminum.
As for the design "channel tongue" another nope, go with tubing. If you ever get into a situation where it's loaded to the max or on a rough road, you're looking for cracked diagonal braces where they're under the front edge of the deck from flexing. IMHO the best style of tongue is one that is a single center tube that goes back two preferably three bunks and two diagonal braces (same idea as what they have now) from the coupler back a couple of bunks either side.
ST tires, I'd go with LT tires, something with some steel belts, not just all nylon.
Just my two cents (1.5 canadian :) ) worth
I have a trailer built with tubing. Never again. The road salt gets into the tubing and rusts it out from the inside. I also have a trailer built with C channel and I beam. It's definitely not as stiff but also definitely does not have a salt problem.
   / Aluminum car trailer vs steel #14
I picked up an older ALUMA brand trailer. I think having some abuse before I got it. I haven't used it much yet, and need to do some "tuning" on it. For some reason, at least some of the brakes were disconnected, so that needs fixed.
The biggest problem is a "Y" shaped tongue as above. 2 bolts hold the hitch on, and they've hogged out the attachment point and the whole hitch is mighty loose.
I'm going to replace the hitch attachment with a piece of tube steel to go over the aluminum tongue extension,
Big mistake. Aluminum and steel are far apart on the Galvanic scale. The Aluminum will rot away in a few years.
The below table can be used as a quick guide to select compatible metals. Where two materials meet in a green region the corrosion potential can be thought of negligible, meaning, a good combination. Materials that meet in the red zone however should be avoided or used with caution.
   / Aluminum car trailer vs steel #15
As suggested by Hughman flat towing is a clear option with a vehicle that can be flat towed. Plus you save the weight of the trailer that will be a great help pulling your long grades.
I've found the most important thing with flat towing a jeep behind the RV through the mountains is to have an auxiliary brake system in the toad. I use rvibrake.
Not sure how the Honda would fare being flat towed, but the Wrangler is a no brainer.
   / Aluminum car trailer vs steel #16
How many years is a "few years"??
My wife just informed me that I bought my Aluminum trailer 15 years ago, and there's NO rot on it at all!
SR
   / Aluminum car trailer vs steel #17
SR
Al on Al is fine. It becomes a problem when dissimilar metals touch. The time for the Al to rot away depends on the conditions. Salt, water, damp operating and storage conditions will accelerate the process.
Places like steel bolts holding on a metal part is where you will see the problem.
Dissimilar metal issues can get involved, and I, by no means, are an expert on this subject. There is a lot of information on the internet for those who wish to learn more.
   / Aluminum car trailer vs steel #18
I can see that happening if the joints are not tight. When I built mine, I drilled and tapped a 3/8" hole in the tubing frame and poured a couple liters of waste oil inside.
   / Aluminum car trailer vs steel #19
If he uses galvanized steel, and galvanized fasteners, he shouldn’t have any meaningful corrosion
There is something about the chart I don't understand.
If I start with aluminum, and go to the right over to steel, it is red.
But if I start with steel, and go to the right over to aluminum, it is green.
What am I missing?
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
