Gasoline storage
/ Gasoline storage #11
I've got (2) 30 gal HYPE(?) drums I got from the local car wash. They had "caustic" chemicals (soap with additives) in them. They are thick walled, have 2 bung holes on top with rubber gaskets and have housed my gasoline needs for over 2 years. (I fill them up every month). Got the drums free from the car wash.
I bought a 12v 55 gal drum pump off ebay to pump the gas from the drums to the vehicles. I use our accumulated fuel points from our local grocer to get $1 off a gallon. Hence 2 drums to maximize our savings.
Works great. Save an avg of $70/month on gas by doing this.
/ Gasoline storage
When you guys are filling these larger containers from the bed of your truck do you mess around with any kind of ground strap?
I do have a tractor with forks so the weight is no problem. Maybe I’m overthinking it but I don’t wanna blow up at the gas station lol.
/ Gasoline storage
On mine its the pump itself. Its not rated for volatility of gas.
So maybe I could get a diesel tank and change out the pump rated for gas?
/ Gasoline storage #14
I use a ratchet strap to hold the drum in place in my pickup until I get it home. I have a 2x10x16' "ramp" that I use to slide the drum onto a roll-around dolly. If you're going to store it outside, then I'd put it up on some sort of platform, like a pallet, or 2x's to keep it off of the soil/gravel.
/ Gasoline storage
Is static during filling the container an issue? I’ve never experienced this filling 5 gallon cans but I keep reading that it’s a thing.
/ Gasoline storage #16
I was going through this myself. I contacted 3 local fire departments. One had no recommendation, and the other 2 said do what the manufacturer recommends (which is NOT fill in the bed of a truck) so I am still using 5 gal cans on the ground. Sucks.
/ Gasoline storage #17
30 gallon drum with crank pump or dedicated fuel caddy?
My carbureted service truck has a 34 gallon tank and I added a dispensing pump which conveniently covers my gasoline needs.
For Diesel I stay with 5 gallon containers.
/ Gasoline storage #18
Yeah the 14 gallon caddies are somewhat able for me to remove/ fill and place back in my beater hatchback for transport steel 35 gallon definitely not and use my single axle trailer with ramp but I only use that one for diesel anyway. I think gas weighs around 6 pounds a gallon so 14 of them is 84 lbs or so + weight of container empty. I pretreat all gas or diesel with additives and only fill gas caddy with ethanol free.
/ Gasoline storage #19
I have two of these. One for gas, one for diesel.
Same here, I have both strapped to a pallet to fork them in and out of my truck after filling.
I had to upgrade the cheap OEM hoses to real fuel hoses after 1 yr as the hoses on the gasoline side got brittle and started craking. While upgrading the hoses, I added a Goldenrod water block particulate filter to each.
Both hand pumps are still working on mine, but my brother had one go out on him after just over a year.
I store mine outdoors with a tarp over them, haven't had any issues other than the hoses.
/ Gasoline storage
So are you guys filling them from the bed of your truck?
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
500BBL WHEELED...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
