Seized blade bolt on woods RM59
   / Seized blade bolt on woods RM59 #1
asgreig
John deere 2210
What's the best safest way to loosen the seized blade bolts on these machines?
Thanks
1/2 inch electric impact will tighten to 130 ft/lb. Hope it works in reverse! lol
   / Seized blade bolt on woods RM59 #4
I haven't found one yet that my 3/4" air powered impact wrench won't take off.
If I do find one, it's torch time. Try just heating it with a rosebud tip first, and then impact wrench. But if that doesn't work, cut it off.
Success! impact was enough!. thanks for all the suggestions
   / Seized blade bolt on woods RM59 #7
Biggest mistake on that Woods is the LH threaded spindle bolt that gets you. Never a problem off but I use breaker bar when putting back on.
   / Seized blade bolt on woods RM59 #8
After years of grunting, pulling, cursing - I finally got an electric impact wrench. A little oil, patience and the impact wrench - has worked every time.
   / Seized blade bolt on woods RM59 #9
If it's really seized, impact wrenches and oil and whatnot won't really work, will they? It's become one piece of metal, welded between the threads in areas. It has to be cut off.
I had an unpleasant experience with this. I had mounted my bucket edge with stainless bolts and nuts, and I had used fine threads to make them less likely to work loose. Big mistakes -- I just didn't know. Similar metals are prone to seizing, and stainless is more so than most. I was dismounting, loosening one of these nuts. It was turning very easily, spinning off with my fingertips, and was halfway off (meaning only half of the nut's threads were still engaged. Then it got a little stiff to turn. Stiffer. Even stiffer. I had to put a wrench on it, and only got another turn. I would up with my 1/2" drive breaker bar with a pipe over the handle, and only got a little further. Finally I used a right angle grinder to take it off the hard way.
   / Seized blade bolt on woods RM59 #10
Air impact may be the best. I have air but no air impact wrench. I do have 1/2" electric impact wrench. Used it to remove blade bolts on my JD 750. Worked just fine.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
16ft Trailer T/A Equipment Trailer (A50322)
16ft Trailer T/A...
