John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #1
VOL54
Member
NW Tennessee
New Holland TC45DA, John Deere 345
Greetings......I have a John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine.... Engine just clicks when trying to start (will finally start)....ongoing problem for over a year....finally decided to replace the starter solenoid today. I got everything all put back together only to discover it's still doing the clicking thing. It was getting late so I decided to start it and move it out of the way till tomorrow morning only to have it quit before I could get it parked. Will turn over but won't start. Anyone have any suggestions as to where I should start to get it running again? Thanks for your help.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #2
Deere 345 has several interlocks on both the start and ignition circuits. The service manual does a pretty good job of explaining diagnostic procedure for each circuit.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #3
Check all your electrical connections, especially around the starter and battery
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #4
"check" meaning removing and cleaning, as sounds like corrosion is possibly causing a disconnect.
Well, it starts now(it was the seat safety switch), but the clicking noise when starting persists. New starter solenoid installed to no avail. Still clicks. Could problem be the starter itself?
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #6
Battery cable connections need removal and cleaning, or battery needs load testing. If that doesn't work, then go after the starter.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #7
check ground wire.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #8
fuel filter or water in gas.
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #9
  • Good Post
Reactions: fc1
   / John Deere 345 lawn tractor w/Kawasaki FD611V 20hp engine....starting issue #10
he said the motor turns over.
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52128)
2021 John Deere...
2011 VOLVO VNL670 SLEEPER (A51219)
2011 VOLVO VNL670...
John Deere Hayrack (A50515)
John Deere Hayrack...
Quick Attach Pallet Forks (A47384)
Quick Attach...
Payment Instructions (A47384)
Payment...
