Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #23,591
Built sides for the old F250 so I could carry two face cords of loose stacked wood.
Test run today to a neighbor to see how it worked. Delivered two cords of oak. I talked him into taking 20" long splits as that is more efficient if you have a firebox big enough. More wood per armload and more wood in the stove/fireplace for a longer burn. I can produce faster with only 4 cuts per log instead of 5. I get 102" logs, so cut at just under 17" or just over 20" so I do not need to deal with ends...we call them cookies.
The truck has a dump bed. He loved that we could tilt the bed , stage the splits on the tailgate, and stack without dumping wood on the ground and having to bend over. We got both cords stacked in 35 minutes.
Picture shows the truck under the outfeed conveyor of the processor. Nice to be a able to run directly into the bed. Got both cords processed in under two hours working along. That included changing a chain and a minor repair to the unit. Looks like I can do a face cord in 45-50 minutes with minimal effort.
Conveyors are key to efficiency in firewood production.
   / Tractors and wood! Show your pics #23,592
Back in the '70's time frame the farm family down the road had 8 kids. They had a wood furnace in the cellar of the big old house. Every fall a logger would drop off about 12 cord of log length firewood in the door yard. The father and 2 oldest boys would work at the log pile blocking off the pile and splitting with mauls. They had about 50 feet of roller skate conveyer, like grocery stores used to have, going from the pile around a corner of the house and to a cellar window with a shoot. The 6 remaining kids would fire brigade the splits along the conveyer and down the shoot. They would work at this on and off for weeks until it was done. People would drive that way just to see it - something to behold, a family at work.
gg
   / Tractors and wood! Show your pics #23,593
gg
Things were certainly a lot tougher for the folks up north, prior to global warming. Burning (12) full cords of wood, to heat a house thru winter, seems mind boggling to me right now. That is (6) times more wood than it takes to heat our house.
I’m way up north myself, less than 30 minutes from the Canadian border. I’ve been averaging less than (6) face cords a year, over the last (5) years or so, to heat our fairly well insulated, 2000 sq ft ranch house.
   / Tractors and wood! Show your pics #23,594
You mustn’t be burning 24/7 wolc.
6 face cords is about equal to a cord and two thirds. For where you are that would be fantastic but your house would be more than “ well insulated”.
I would guess that you’re supplementing with wood heat.
For me it’s the other way around.
I recall in the late 80’s early 90’s how you could heat a mega insulated house with light bulbs.
I have R-30 in the roof and R-17 in the walls and l go thru 3 cords with the stove in the living room burning round the clock. Mostly all oak.
My old house took 5-6 cords with the stove in the unfinished cellar.
Both houses are. 1700-1800 sq.
gg
good story Gordon.
   / Tractors and wood! Show your pics #23,595
If we are assuming 16" long pieces, 6 face cords equals 2 full cords.
A local friend here in the Champlain Valley of Vermont built himself a super-insulated 1550 sq ft home (not including the 880 sq ft unfinished basement). He heats it with a little over 1 cord of firewood a year. Even in a bad year, he's still under 1.5 cords. I've been in his house on multiple occasions in the winter, and it's always comfortable. The house has no other heating system other than his wood stove.
   / Tractors and wood! Show your pics #23,596
I just read about a place downstate which makes houses which
meets the “passive house” efficiency standard, which means it uses thick insulation, tight air-sealing, solar panels and other features that can result in net-zero energy emissions
I'm not sure that I want a house which is that air tight.
   / Tractors and wood! Show your pics #23,597
good story Gordon.
There are (2) natural gas furnaces in the basement of our L-shaped ranch, one for each wing. They only run on winter days when the temperature at sunrise is above 35 F. It gets too hot in the house if we use the wood stove when it’s that warm.
I thought we were only going to use (5) face cords last year because the winter started out very mild. Spring was colder than normal though, so we wound up using a total of (6), right on the average.
   / Tractors and wood! Show your pics #23,598
Houses which are very airtight should also include a heat recovery ventilation system which brings in fresh air and heats/cools it with exhaust air. When I remodeled my house and added insulation and new windows I added a system to exhaust air from the basement and bring fresh air into the first floor.
   / Tractors and wood! Show your pics #23,599
Exactly. We built a tight house and included a Heat Eecovery Ventilation system (which also works to cool incoming air in the summer if we have been running the AC).
In hot, humid southern climates, people may want to consider an Energy Recovery Ventilation system, which also recovers relative humidity in addition to the heat/cool recovery.
   / Tractors and wood! Show your pics #23,600
It’s nuts what some homes are capable of energy efficiency wise but it is definitely the way to go.
If you are using traditional methods of measuring cordage, you’d be correct.
I learned a long time ago that this would be a falsehood of actual wood volume and is why l said it was less. Just a guess of how less on my part but maybe too less. I should have said more like a cord and 3/4’s.
I’ve always measured out to 10 ft instead of the 8 for stack length to account for air space.
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52128)
2022 JCB 3TS-8T...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
