Hyd motor on post hole digger
/ Hyd motor on post hole digger #1
kthompson
Elite Member
South Carolina
Kubotas B2710, M6800, L6060 cab, Volvo EC excavator, 2 ZTRs and various implements.
I have found some info on this but wanted to narrow the conversation to be certain.
I have thought for a good while about installing a hyd motor onto a pto driven post hole digger. We don't have stones but we certainly have tree roots.
A thought popped into my mind when talking with a nephew who really needs a hyd driven digger due to roots. Will the post hole digger have any issue with reversing the direction? The only reason for reverse is to free it from tree roots so not trying to run it backwards much.
Also, any suggestions on a motor to run the digger? Do they have a direct drive suitable motor?
Thanks for your help. Kenneth
PS: I got out of my farming about four years ago. I slowly sold most family equipment and kept a few items. Ended up with three Kubotas from 27 to 68 hp. Even stopped buy diesel in a 150 gallon tank due to how much the use dropped. Now looking towards retirement following my wife who is now the bigger tractor user. I enjoy helping her learn the front end loader. She was always good with rear mower. This got me off here as I really was not using tractor nor equipment much. Again thank you.
/ Hyd motor on post hole digger #2
Those is the motor I have on mine it is made Boland pride model hp25 I believe
/ Hyd motor on post hole digger #3
Kt,
Motor size depends on several variables some of which are, torque required, RPM required, flow available, pressure available actual differential across motor.
Trying to direct drive you need bearings strong enough to support the thrust or pull load when pulling auger out of the hole and if loader mounted pushing into the hole. I think most augers have gear box for this reason and also step down motor speed to keep motor smaller.
Most motors will operate both directions so reverse is not a problem for the motor.
Are you considering converting an existing PTO unit or looking for new hydraulic drive unit?
I believe both Digga & Danuser make hydraulic drive augers but sure in what sizes.
/ Hyd motor on post hole digger #4
I've only drilled a few holes with it so far, but I'm very happy with the hydrualic conversion on my post hole digger. Surplus center sells splined shaft motors that attach to PTO shafts.
/ Hyd motor on post hole digger #5
Surplus center has hyd motors to PTO shaft. I believe that's what your looking for? You would still use the gear box so just want to delete the drive shaft correct?
Kt,
Sorry for the delay, work got in the way.
I am wanting to basically replace the pto power and installed hyd motor to replace that. I realize there are true hyd powered digger, but price is way beyond what I can justify for my seldom need.
Of course if you have the equipment it is amazing the jobs you NOW HAVE to do.
Thanks for your info. KT
WOW! Great details and job. Now to take your info and the others thoughts need to get with my nephew (who needs it more than I) and see what we can do. I really do appreciate each one's input.
KT
/ Hyd motor on post hole digger #8
/ Hyd motor on post hole digger #9
Is this what your looking for? B2301, 18" bit all clay 4' tubes no problem.
/ Hyd motor on post hole digger #10
/ Hyd motor on post hole digger #11
Any concerns about the long arms putting too much torque on the loader arms when in use? Is that even an issue with tractors having such a low GPM on the hydraulics? I have an old Ford auger very similar to yours I might convert like that.
/ Hyd motor on post hole digger #12
Pretty cool KsJoe!
Local fellow sells Wolverine SSQA to 3pt with hydraulic pto for $650-750.
Scrapyard I’ve sourced 3” x 10’ well drilling pipe. Course very tapered threads and much thicker wall where threaded. Don’t know about running reverse without pinning joints.
I’m in the same boat as the OP. Like an easier way to drill an occasional hole. Have an old Ford auger. That auger stump planer looks pretty cool too.
/ Hyd motor on post hole digger #13
Nope. Look at the gpm and relief pressure of your tractor. An online calculator can tell you how much HP that works out to. It will be less than the PTO HP of the tractor. So if its spinning close to the rate of the PTO, and has less HP, the max steady state torque must be less.
If it gets stuck suddenly, there's less rotating mass than the PTO drive line, so the shock torque should be less too.
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2016 Freightliner 108SD 26Yd. Side Loader Garbage Truck (A64194)
2016 Freightliner...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A67147)
1997 KENWORTH T300...
