HELP - NEW Lawn tractor with Hand/Lever hydro static control
   / HELP - NEW Lawn tractor with Hand/Lever hydro static control #11
Hello, does anyone have experience or have seen some brand which offer lawn mower tractor with hydrostatic hand speed lever?
Idea is that lawn mower tractor as this one only without pedals for speed control
   / HELP - NEW Lawn tractor with Hand/Lever hydro static control #12
This is an old thread being awoken now;
I know of nothing modern that uses a hand control lever for the hydrostatic, also all the older ones I know of had a foot pedal (clutch) that ran a dump valve to disengage the drive.
So even if a person ran a lever with a cable down to the linkage you would not have that "safety". As all the hand controlled ones also did not have a spring to neutral the speed direction lever stayed were it was placed.
   / HELP - NEW Lawn tractor with Hand/Lever hydro static control #13
Huskvarna units have hand lever. Forward, reverse and speed control. Still has foot brake. But these arnt true hydrostatic. There belt driven.
Driving it though…cant tell any difference
   / HELP - NEW Lawn tractor with Hand/Lever hydro static control #14
Steiner is a hand control on my 1994 420 model. No safety's on these older ones. (so you must be more careful about operating them of course)
   / HELP - NEW Lawn tractor with Hand/Lever hydro static control #15
Country Clipper has had the joystick operated ZT mower for YEARS. This is the 10th mowing season on mine and haven't had a single problem with the system in the 540 hrs. on the machine. Not even any adjustments to the mechanical linkages (doesn't use cables like some tractors). I've used a little spray lube on it at times but not often, just to keep any rust etc. from forming during the winter when stored in an open shed.
You only need 2 or 3 fingers of one hand to operate the mower with your arm resting on the armrest. I have posted this many times over the years in a couple of different forums but have only heard of 1 or 2 other people ever mentioning anything. I wouldn't even consider any mower without the joystick anymore what with all the fruit trees I have to mow around/under. Having your left hand free to move branches and being able to bend over in the seat as to not hit your head and still have precise control of the mower is great !
   / HELP - NEW Lawn tractor with Hand/Lever hydro static control #16
The John Deere 300 and 400 series garden tractors were hand operated with a short lever in the right side of the dash. But they quit making them around 1991.
1262 (A50490)
1262 (A50490)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
2011 FORD F-450 (A50854)
2011 FORD F-450...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
434669 (A48836)
434669 (A48836)
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
