Good morning!!!!
   / Good morning!!!! #191,271
63F, overcast, and damp out @ 12:30, calling for a high of 71F for the day. Some lingering showers in the NEO area.
Got meds doled out first then yesterday morning.
Then got all the mowing done down here around the house.
Mixed up some seed and put it out for the ground feeders, tube feeders will need refilled today. They also need relocated, squirrels have figured out how to get to them by climbing up on the old cedar stump and jumping over.
Bluebirds back at Nest Box No. 2, will check it to see if they have laid another batch of eggs. Maybe put out some mealworms for them.
Checked the one remaining tire on the rolling seat that was loosing air, and it's happening pretty quickly ... so will head up to Menards in Kent in a bit to pick up 2 foam-filled tires/wheels and be done with messing around with it.
They supposedly have black mulch in stock, so will try to pick that up as well.
Drilled five 1/4" holes in the little tray on the rolling cart so it will self-drain if it gets left out in the rain.
Took both the pneumatic tires off and moved them up to the shop for the upcoming bearing swap, along with some other junk including the oil drain pan and got that emptied into the 55 gallon waste oil drum.
Located the small pan that will be used to heat up the seal that needs to be heated to install on lift cylinder piston while I was up there.
Woman continued cleaning up around the outside of the shop, sprayed several gallons of glyphosate, and I reloaded the sprayers for Her several times.
Ran over one of the short t-posts with a wire cup brush in the grinder then got it primed. Also got about 1/2 the topcoat applied (one side)
Moved the one arched trellis up so the bottom is about 1' off the ground and reattached it to the t-posts. (Gives the plants more room to grow) Will do the other one when I get the t-posts for it repainted.
Planted 1 Hot Lemon pepper and 1 Habanero yesterday to see how they would fare overnight with the critters. Looks like they came through the night undisturbed ... (y)
Trimmed some seed heads off the rhubarb, it is doing very well:
Probably will relocate that to an unfenced area this fall since the critters leave it alone.
Russian Sage has also gotten to the point where it probably should be divided:
Same deal with that: relocate to an unfenced area since it isn't prone to being eaten.
Woman just went around back to release a bird that had somehow managed to get inside the netting over the strawberries.
She made shortcake from scratch a few days ago to go with the strawberries She harvested, was delicious.
Burning daylight, need to get moving ...
Hope everyone is having a decent Sunday ... (y)
   / Good morning!!!! #191,272
Good afternoon! 88˚F cloudy, S wind.
The Mesquite wood floors turned out great. Our realtor is making one of her bedrooms a study and will move the wife's desk. The consignment store would not take the desk because it was too big (60"x30").
Todays little project, besides moving more boxes, will be to clean out the dryer vent line in the new house before they move the dryer in. It is about 30' long going through the slab in the garage. I hope I have enough extensions or might have to go in through both sides with the drill brush.
   / Good morning!!!! #191,274
RS, what happened in Akron, shootout at OK Corral?
might not want to drive in that neighborhood at night.
must be gangs blasting away at each other
24 people shot after midnight
might want to get home earlier on your downtown night out...
I thought downtown Akron looked pretty nice but perhaps if one strays off
Firestone Avenue...the neighborhood changes.
   / Good morning!!!! #191,275
Drew, I would go after the Mower issue in a systematic way starting with easiest issues first
Check that fuel is flowing freely up to the inlet of the injection pump and next
bypass all switches that can shut the engine down
if not found check if there is an inlet screen on the injection pump
still not found take the tank off and see what is rattling around in there
   / Good morning!!!! #191,276
Some more info from brothers wife. He felt bad and Dr thought it may be stomach ulcer. Was on meds for that for a week and then felt worse. Took him to hospital and they said heart issue and water in the lungs and drained the fluid in the lungs. 2 days later when he felt better he left. He had previously had several arteries replaced for plaque
He is now dizzy and feeling bad again but refusing help
Worried about him.
   / Good morning!!!! #191,277
Good Morning Dennis,
That is very interesting! We are looking forward to touring the estate !
My wife is a Lincoln, and is listed in at least one book showing the Genealogy of them from Abe’s great grandfather ‘Virginia John Lincoln’ . “Capt Abe Lincoln, Abe’s grandfather is 1st son of Virginia John. Born in Berks, PA, moved to VA with the family as a child. Moved to KY 1780. In VA lived next to his father, near where my wife lived. Wife's lineage is from another son of Virgina John L.
   / Good morning!!!! #191,279
67°F and 1.25 inches rain
Headed for airport in a couple hours to begin our sojourn to the mainland. Granddaughter graduates HS on Tuesday. Longest flight is today starting here in Hilo finishing tomorrow at Washington Dulles.
Prayers for all
Be safe
Have a great day
Have safe trip and enjoy the visit.
   / Good morning!!!! #191,280
Nice day today. Mid 70's and mostly sunny.
Went to a friend's house and dropped a tree for him. He doesn't exactly have any experience on how to do it while standing. He can handle it on the ground.
Went to my dad's after that and started cutting up some logs he has. Made good headway, little bit left.
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2018 Chevrolet Silverado (A56858)
2018 Chevrolet...
2015 Chevrolet Equinox SUV (A56859)
2015 Chevrolet...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
