rpm problem
/ rpm problem #1
Tigger4982
rk37
I purchased a rk37 used with 300 hours
rpm will not go higher then 2100
it bougs down under load
I clened all fuel lines and replaced with new filters does anyone else have this problem
/ rpm problem
I replaced air filter and did regen exhust seems strong
/ rpm problem #5
Regarding it bogging down under a load, what gear/range are you using? In general, if it starts bogging down, I move it down into a lower range/gear.
Regarding the rpms, maybe check the throttle cable to make sure that it has the full range of movement. Move the cable with your hands (versus the lever) while it’s running to still if you can get it over 2100 rpm.
/ rpm problem
ther is no throttle cable it is electronic I ran it in low gear
thanks i am veteran also
2023 Chevrolet Silverado 5500HD Auto Crane 6006EH 6,000lb. Crane Mechanics Truck (A64194)
2023 Chevrolet...
2022 EZ-GO ELITE...
Cattle Feeder (A65640)
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
New Holland 256 Hay Rake (A65579)
New Holland 256...
