Any smaller DIY mechanical thumb plans available?
   / Any smaller DIY mechanical thumb plans available? #1
DonRina
Vancouver Island
Jinma 354
Just wondering if there are any diy mechanical thumb plans available for my 354 chinick tractor with a lw8 backhoe? I’ve found some kits on Ann but they are a weld together type so I thought I might as well just fab one up myself if possible, scrap metal being available locally.
   / Any smaller DIY mechanical thumb plans available? #2
Decent wire feed welders are cheap nowadays, and any bolt together solution is going to start rounding out holes sooner or later. Not to mention that any holes you drill in your dipperstick are going to weaken it. I would strongly suggest a welded solution either learning yourself or cutting the parts and having someone else weld it up.
I have a mig welder, good for 1/4” and my neighbor has a 240 v stick welder so I can weld one up…but if I’m welding up a kit why not just fab one up from local stock, hence my query. Saves shipping cost and might be a better unit.
   / Any smaller DIY mechanical thumb plans available? #4
Do you have an easy way to cut metal shapes out?
Well, I don’t have a plasma cutter but might have access to oxy/acc cutting torch. Locally, maybe a cnc file and water jet. More expensive though.
   / Any smaller DIY mechanical thumb plans available? #6
I cut and welded this from scrap metal peices.
My BX23S has an attachment point for a thumb. Cut all of the parts with a grinder and 4 1/2" cut off wheels.
   / Any smaller DIY mechanical thumb plans available? #7
Nice simple design that works!
I like it! I’ll see if I can emulate it for my lw8, chinick unit.
   / Any smaller DIY mechanical thumb plans available? #9
An standard oxyacetylene torch will do that job.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2013 International Derrick Digger Truck (A55973)
2013 International...
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
