CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,444
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I've spent the past few days removing a couple of stumps that have been a PIA for some number of years since the trees were felled. The exposed stumps of both appeared to be well decomposed, but that turned out to be an illusion. The little Hurlimann 435 had it's work cut out! (But both stumps are now out back on the "stump pile" ;-)
To the point,
Though most of the real digging was done in the lowest of the 12X12 gear box, In effort to speed soil burden relocation, 3rd gear would be selected for travel to and from the nearby dump pile. Late in the afternoon, I went into the stump diggings in that same 3rd gear and promptly stalled the engine. No issue said I, a simple restart, and back out. But NO! The turn of the starter key did nothing! Nadda, Not even a panel light. What the heck!??
Blinkers? OK, Work lights? OK, Headlights? OK, Flashers? OK. But no starter or engine heater indicator lamp.
Suspecting a loose wire at the starter switch, I removed the instrument cowl , which requires removal of the steering wheel! Jeesh! Who designed that? All connectors good.
But a 30 Amp fuse was blown.
Hmm... What would blow the starting system fuse ?
Fortunately, I had a spare in my stock of things. But now I'm worried ...
Was it a freak coincidence of glow heaters turned on while the starter motor was engaged?
I usually wait until the glow light times out to activate the starter. But in this incident, I reached for the key only moments after the engine bogged.
Any ideas?
I'm going to purchase a couple more fuses (30amp) to have on hand...;-)
To the point,
Any ideas?
