can a rechargeable 12v battery power a pump?
/ can a rechargeable 12v battery power a pump? #1
nancyk
east Tennessee
Deere 5055e 2015, Ferris IS2000z 2007
can a 2.2 Gal. per minute 12-Volt pump on a 3 pt sprayer (Workhorse 40 gal 12 volt with 5 nozzle boom for utility tractors) be powered by a 12v 35Ah rechargeable battery? This sprayer has not yet arrived but I already know the wiring harness is 8 ft long and will not reach the battery in front of the tractor. It will eventually be wired to a 7 pin connector to be powered from the back of the tractor at the seven terminal outlet and hope to get that also connected to an off/on switch to be used from the tractor seat. I have some rechargeable batteries I use for my front gate opener and could use one temporarily until we get the wiring done.
Nancy
/ can a rechargeable 12v battery power a pump? #2
Looking at the Workhorse spec, the current draw of the motor is less than 7.5 amps as determined by the recommended fuse. They actually give nothing about typical running current.
What type battery are these rechargeable batteries? NiCads? Or Lithium Ion? The battery type matters.
My guess is that if you run from full charge, you might get 2-3 hours of proper operation. Going just by amp hour capacity not knowing the battery construction, let's assume the motor needs 6 amps at 12 volts to run full speed and do its job. Lets also assume the battery will hold the voltage to around 12 volts until it is about 50% discharged. That means you would have 16-17 amp hours of use. At a 6 amp draw, you will hit 50% discharge within 3 hours.
In real life, the voltage will sag as the battery discharges so the motor will slow. As the motor slows down, you will loose pressure and the spray will not be applying at the rate you need.
It worth an experiment I suppose... but may destroy the batteries in the process.
Wouldn't it be better to run a temporary wire to the tractor battery distribution panel? Use a heavy duty electrical cord and tie it up so it does not get caught on anything until you can make your permanent installation?
The difference being the tractor's alternator/generator will carry the load more than the battery.
"may destroy the batteries in the process." that is what I am concerned about. The batteries I would like to use, temporarily, are the ones I use for my gate opener, which has a solar panel to recharge. However, for the past 3 years it has not been recharging so I exchange the batteries every three weeks, then do a trickle charge for the day, and am set to go. When I get this new sprayer system set up I would like to try it out but do not want to make any changes to it(adding a 7 pin connector power system) until I see how it functions. What is the battery distribution panel? I believe, ultimately this sprayer system will suit my needs(spraying a mile of gravel driveway 4x/year), but would like to try it out before altering powering systems.
Batteries are sealed lead acid battery. 7.5" wide x 6" tall x 5" deep.
/ can a rechargeable 12v battery power a pump? #5
I agree with WranglerX. Why try to get exotic when your tractor system can handle it so easily.
/ can a rechargeable 12v battery power a pump? #6
I have found it works wonderfully with a standard car battery on my AE long wheelbase work cart. I found a RAV4 trailer hitch that fits it perfectly and then found a hitch carrier at an estate sale. It holds a 25 gallon spray tank. The pump is what you have shown and has the on-demand option (runs only when actively spraying). I run 4 spray nozzles at a 4' separation for weed and feed on my lawn. With a hand held wand with a trigger, it will shoot a solid spray more than 20 feet. Since the cart is 48 Volts, it was easier to power it from an extra car battery. Haven't had to recharge the battery yet this year. (The over size load banner is a joke).
"Just wire it to tractor when it arrives" as I do not have the system yet but have looked at what is included with it, I believe it comes with clips to attach to a battery. How can it (easily) be wired to the tractor? I have ordered a Tectran 7-Way SAE Plug with Spring Guard and am hoping my electrician neighbor can set it up for me. He has a lot on his plate so do not know how quickly he will be able to do this.
/ can a rechargeable 12v battery power a pump? #8
The power for my sprayer is via the 12V (aka cigarette lighter) outlet in the cab when using the Kubota. It has an inline switch on the wiring before exiting the cab that's used to switch power to the pump when the spray boom is used.
When using the Ford, it uses a "flat two" trailer connector. The Ford has a rear light on a separate switch that uses the same flat four. Just unplug the light and plug the sprayer in. Light switch controls ON/OFF.
When using the wand, no need to switch because of the on-demand pump. Power to the pump stays on constantly.
As the tractor has no cab, it has no 12v outlet. The current spray system is powered by a plug to the seven terminal outlet on the back of the tractor and is easy to connect and disconnect.
"may destroy the batteries in the process." Just curious, how could this occur? If the 2.2 gpm pump ran continuously while connected to the 12v battery, wouldn't it just drain the battery?
/ can a rechargeable 12v battery power a pump? #11
Thank you. Could not find what I was looking for. Some videos were for pto powered systems and some showed how to connect to battery via 2 pin clip. Connecting directly to battery in front of tractor is not doable.
/ can a rechargeable 12v battery power a pump? #13
If you have a 12V lead acid battery, it should really be kept between about 11v and 12.6v or so. Drop it down below 10v, and you have a chance of doing permanent damage to the battery.
Drop it down to, say 6v, and you almost certainly will reduce the life of the battery.
A lot of devices will have a low voltage cutoff, but many electric motors will just run until they can't get enough juice to move, at which point you're in the danger zone.
Some will depend on how you're using your sprayer. Is it a large area sprayer? Wand operated spot sprayer? Continuous use near peak power? How long?
As far as wiring it into your tractor. Every setup will be different. But, if you have large alligator clips (battery charger clips), then just clip the to the tractor battery, and add long enough wire to reach the sprayer. Probably just two strands (+/-). You'll need to route the wire so it doesn't interfere with anything. Perhaps some plastic zip-ties, or some bailing twine, or whatever you like to hold stuff up.
/ can a rechargeable 12v battery power a pump? #14
Is there a reason why you can't power the new pump off the same seven terminal plug? Just get the plug end and wire it to the new sprayer. Or, add wire and battery clips as mentioned temporarily.
"power the new pump off the same seven terminal plug" yes, I could. But. I plan on keeping the old d.i.y. sprayer setup as a backup. It currently is functioning and rather limping along. I have ordered a new identical(so I know it will fit in the tractor outlet) 7 terminal plug, it should arrive shortly, the sprayer should be in at Lowes next week too. I just need to get a off/on rocker switch and I will be ready for my electrician friend to go to work.
/ can a rechargeable 12v battery power a pump? #16
Most any auto parts store sells the rocker switch and rolls of wire you need.
Good to know, thank you.
/ can a rechargeable 12v battery power a pump? #18
One has to wonder if the 7 pin connector is same as found on pickup trucks..... And Why you had to order it through a home building supply....
/ can a rechargeable 12v battery power a pump? #19
Her 7 pin connector for a 5055 JD probably looks like this. Id. presume you can piggy-back 12V and ground by add 2 extra wires to the current sprayer feed (so to speak !). You get what you Voltaged for....
/ can a rechargeable 12v battery power a pump? #20
Is that the same as a semi trailer plug?
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
Zero Turn Mower (A59231)
Zero Turn Mower...
John Deere 24'' Backhoe Bucket (A60463)
John Deere 24''...
