Kubota ZD21 zero turn mower starter issue ?
   / Kubota ZD21 zero turn mower starter issue ? #1
Cycledude
Rib Lake Wisconsin
LS XR4155, Ford 6610, Ford 8n
I am the very well satisfied owner of a Kubota ZD21 but it has been suffering with a starter issue for several years and I would like to fix it.
The starter motor seems to run fine but the gear very often doesn’t engage to turn over the engine, do you think just replacing the solenoid or whatever you call that thing sitting on top of the starter would fix it ?
Amazon has several choices for a complete new starter for what seem like pretty reasonable prices so maybe I should just go that route ?
or maybe someone more mechanically inclined than me has some helpful advice ?
Thanks for your help !
   / Kubota ZD21 zero turn mower starter issue ? #2
You may have a bad Bendix but it's also possible your starter doesn't spin initially with enough speed to throw the Bendix into the ring gear in the engine. A complete starter may be a better way to go. Of course it's also possible your starter isn't getting full voltage when activated. You may want to compare that voltage against the battery voltage and be sure all terminals including frame ground are clean and tight.
   / Kubota ZD21 zero turn mower starter issue ? #3
Or maybe you just need to clean the bendex. They can become gummed up and not move up when the starter spins.
Richard
Well I ordered the brandnew starter from Amazon for $68 delivered.
Arrived yesterday, today I installed it and so far it’s working perfectly !
I like to support my local dealer but they wanted $205 plus my old starter.
It was a fairly easy job to replace it but in the process I discovered one of the hitch bolts was missing its probably been missing since the machine was new, replaced the missing bolt cost $1.29
  • Good Post
Reactions: JJT
   / Kubota ZD21 zero turn mower starter issue ? #5
Glad to hear you're up and running. I have had good luck with the sub $80 starters on Amazon. I recall the OEM starters for my ZD326 And previous ZD331 being more expensive, like in the $300-$400 range.
Well then apparently starter failures aren’t really very unusual ? This is the very first time I ever had trouble with a starter. Yesterday when I stopped at hardware store to buy the replacement missing hitch bolt I parked next to a older Chevrolet pickup that had a box of tools and a starter laying next to it, the guy said he had replaced the starter a couple months ago but it failed again yesterday while parked at hardware store, the starter came with a lifetime warranty so the outfit he had bought it from were supposed to be bringing him another new starter.
   / Kubota ZD21 zero turn mower starter issue ? #7
You probably need to install a relay between the starter cable and the wire from the ignition switch. Fairly simple. I've done it on a couple of my kubotas and no more clicking when you turn the key. YouTube video .
The new $68 starter I bought off Amazon has been working perfectly for over a year now, I believe it was a very good investment.
   / Kubota ZD21 zero turn mower starter issue ? #9
I don't know about the ZD21 machines, but my ZD326 and previous ZD331 both had starter solenoid issues on a frequent basis. Rather than always replacing the solenoids (aftermarket about $20), I installed heat shields and solenoid relays and haven't had a problem since. I think the starter and solenoid was taking too much heat from the exhaust manifold, resulting in frequent failures.
You may want to see how close yours is to the exhaust manifold.
   / Kubota ZD21 zero turn mower starter issue ? #10
Knock on wood, ~25 years and 1200+ hours and I've had zero issues with my ZD21, other than new front tires.
LOT: Steel Work Bench w/Contents, 40" x 75" (A59076)
LOT: Steel Work...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2017 JOHN DEERE 544K-II WHEEL LOADER (A52709)
2017 JOHN DEERE...
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
