PTO issues Craftsman Pro Series 8200
   / PTO issues Craftsman Pro Series 8200 #1
JimyIronatx
Hi,
I have a Craftsman Pro Series 8200 lawn tractor that the PTO cuts off while mowing. Eventually it comes back on but doesn't last long enough to cut the lawn.
The battery is new and voltage is 12.7 volts.. checked voltage while it was running and I was getting 15.5 volts.... so that all seems good. I ended up replacing the PTO switch, key switch and the electronic PTO. It does start better but still the PTO will cut off and not work correctly.
Anyone have any ideas of what could be causing the issue?
Thanks,
Jimmy
   / PTO issues Craftsman Pro Series 8200 #2
Jimy, no I don’t have any idea what’s going bad but I do know how I would check it. I would attach two wires in parallel with the PTO clutch. Then you know if it’s dropping power or not while you monitor it during operation. It will take a lot of trial and error out of the problem. Good luck sir
   / PTO issues Craftsman Pro Series 8200 #3
Is there any difference when using the mow in reverse feature? Welcome to the group.
   / PTO issues Craftsman Pro Series 8200 #4
Hi,
Thanks,
Jimmy
Are there any safety switches not you may have missed that are not working properly? Seat, neutral, reverse gear selector are just some of the safety switches found on other machines.
I also replaced the interlock switch, ....but not the seat, neutral or reverse gear selector. I looked at the schematics from sears parts and didn't see anything about a neutral or reverse gear selector switch. Is there a good place to get better schematics?
Thank you,
   / PTO issues Craftsman Pro Series 8200 #7
Thank you,
Not sure about other sources for schematics but best way is to have a look under the seat and around the linkages for wires that lead to safety switches. Schematics are handy for sure but often very model specific. Don't know how correct the one you have is..?
I haven't tried the mow in reverse feature ... I'll give it a try today and let you know.
I ended up replacing the voltage regulator and interlok switch... The mower initially did the same thing and then seemed to straighten up and run and PTO would cut on ... and it all started working. So I thought I had it fixed... moved four times around the yard.. large back yard.. and it started doing it again. Funny thing is this time.. if I stepped hard on the forward ( PTO still engaged and blades not working) the PTO would come on ... each time I pushed forward fast on the pedal .. ... but ultimately the PTO clutch will cut off and it won't work.
I checked the battery voltage again...13 volts.. and checked charge while mower is running fast idle.. 15 volts.
So now I've replaced the PTO switch, Ignition switch, Electronic PTO clutch, voltage regulator and interlok switch. lol...
Frustrated with this thing....
Thanks,
Jimmy
   / PTO issues Craftsman Pro Series 8200 #9
Did you activate the mow in reverse and did it make a difference?
   / PTO issues Craftsman Pro Series 8200 #10
Thanks,
Jimmy
You have a right for your fluster. You got a lot of new parts. Question is, is it really fixed?
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
Sakai SW880-1 (A55272)
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
Quick Coupler (A57149)
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
