F3990 vs newer F3710 4wd front deck mowers
   / F3990 vs newer F3710 4wd front deck mowers #131
@braap736 I just picked up a ZD-1211 and it is better on hills than the ZD-331 it replaced.
I just got home from mowing very steep hills with damp ground and it did very well. I think Kubota switching to a low profile tire/rim assembly makes a difference.
My F-3680 is getting used less and less each day.
I might sell it and go to 2 zero turns instead.
Nice machine, but for only a small amount of cutting it might be time to think about selling.
   / F3990 vs newer F3710 4wd front deck mowers #132
Thanks you guys, didn’t want to start a new thread because I have a hill very similar to the OP’s and am going back and forth on an f series/1400 series Deere or a zero turn.
Zero turn would probably be much quicker but unsure if it can handle these hills. Plus I have 2 ponds to mow around so if it slides sideways I’ll end up in the water. I need to find a rental zero turn to try before buying.
@braap736 my ZD1511 with fluid filled tires does FANTASTIC on my steep banks as long as soil is BONE DRY.
This bank is the only reason I bought the 4wd & it too is going to need all 4 fluid filled.
You may aughta buy hay dudes front deck.
The Big Zero will still be doing 80% of my weekly mowings because it’s unbeatable all around.
With front weights & mentioned rear fluid filled : it rides pretty dang good for a Zero but it has Way bigger tires than all other Zero’s
   / F3990 vs newer F3710 4wd front deck mowers #134
Do you know what angle your steep slope is? Also does your f series ride smoother than your zero?
My Post # 617
I hadnt really mowed enough with this F Series to tell which rides better but the deck bounces around pretty bad & im not mowing fast at all.
You have to take into consideration what diameter FRONT & rear tires on the Zero mowers because it makes a HUGE difference.
The Heavier the mower = the BETTER it Rides.
The ZD1211 & ZD1511 probably rides better than any Zero out there because they’re much heavier.
   / F3990 vs newer F3710 4wd front deck mowers #136
Thanks, steeper than what I got here. I measured 20 degrees at the steepest part. I’m going to have to rent/demo a large zero turn and I’ll know right away if it will work
I’d think if your bank is dry : a heavy zero will be enough
BUT U have to stay STRAIT going downhill & go as slow as possible.
IF you start pulling back on handles it’ll make the tires skid & youll slide like grease
I’ll use my fingertips just BARELY moving forward going downhill staying strait as an arrow.
Turning around at bottom where it’s not steep.
I mow some horizontal swipes but it’ll slide like glass IF soil is damp.
THATS what I’m hoping this 4wd F will do …..
   / F3990 vs newer F3710 4wd front deck mowers #139
In a nutshell an F is a trade off of the speed of a Z for improved traction.
   / F3990 vs newer F3710 4wd front deck mowers #140
I don’t know who you are addressing your question to, but in my case my slopes are so steep that you need to be a very skilled operator or you will be sorry. I’d say 20+ degrees.
My F rides considerably worse than my zero turn, other may have different results
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
Bobcat T590 (A53317)
2014 Gravely 60" Zero Turn Commercial Mower (A55973)
2014 Gravely 60"...
