R1 VS R4 massey 1547
/ R1 VS R4 massey 1547 #1
moparguy55
Massry fergusson 1547
Hello
Tried an old 8 foot wide tow behind disc harrow with 2 rows on my cabbed 1547 hst 4wd with R4 that have seen better days that have calcium in them. Have 18 acres to turn over.
Maybe im expecting too much from it. But anymore than 4 inches of soft terrain and its stuck. Had to use the bucket many times to crawl ahead.
R1s be a game changer? Or?
Im wondeting at 4000 lbs with the compact size tires if its just too much for it? Maybe should have got an older heavier gear tractor for this. The land isnt flat either.
Mind you this is a 1 time job as it had corn planted. I plan on using a tiller after for 2-3 acres to prep to plant some crop.
/ R1 VS R4 massey 1547 #2
R1’s would be a huge game changer. they have 3” tall “paddles” on them that will pull you through loose dirt.
Of course more weight always helps.
/ R1 VS R4 massey 1547 #3
Hello
Tried an old 8 foot wide tow behind disc harrow with 2 rows on my cabbed 1547 hst with R4 that have seen better days that have calcium in them. Have 18 acres to turn over.
Certainly the R1 tires are much better for what you are doing than R4s. The 1547 was sold in both 2 WD and 4WD versions. Do you have 4 WD ? Obviously you need it regardless of what tires you are using.
thanks
As it has R4 on it im trying to figure out what the equivalent stock size R1 would be. Cant seem to find any info as to what stock R1 size for it would be.
Yup its 4wd and still had to crawl with bucket.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
