Adding intermittent wipers to a CK4020SE (or any cab model)
   / Adding intermittent wipers to a CK4020SE (or any cab model) #11
Using the Dorman switch may be possible if the high speed or low speed part of the switch is not used. Looks like it would require a two speed motor in the wiper and a second relay to use all that the switch offers. Darn I thought I was onto something! I think the only way this switch would be worth pursuing is if the wiper motor is two speed but only one speed is used for this application. I will pull the cover off a wiper motor and see if there are two terminals (not counting ground).
Looks like @cioti was right!
   / Adding intermittent wipers to a CK4020SE (or any cab model) #12
I just go inside until it quits raining or rains harder . . . :cool:
Let us know if it works! Might be an interesting upgrade if it's cheap and easy.
   / Adding intermittent wipers to a CK4020SE (or any cab model) #13
If the wiper parks when you turn the switch off, like in a car, the amazon unit would work. It's just a little fragile looking for my tastes. Maybe desolder the potentiometer and remote mount the board in a little box under the dash.
If the wiper stops wherever it was when you turned it off, things get more difficult.
In the former, a delay box only has to supply power long enough to get the wiper moving, then the motor takes over and completes the cycle. In the latter, you'd need to know the exact time (impossible because of variable load) for one complete sweep and keep it powered for that long.
   / Adding intermittent wipers to a CK4020SE (or any cab model) #14
The kioti wiper has a park function.
   / Adding intermittent wipers to a CK4020SE (or any cab model) #15
For the application you’re probably choosing the wrong part. From the schematic I looked at, there are not any unused motor contacts and it is a single speed motor.
The Dorman (&others) is a nice compact full feature unit which would require almost a complete rewiring to utilize.
The unit I linked (& other similar) would be (IMO) easier to wire in but more difficult to find a suitable mounting location.
   / Adding intermittent wipers to a CK4020SE (or any cab model) #16
Just added this feature to my Kioti DK50se HST this past weekend by using this relay module:
or this one: https://www.amazon.com/dp/B0CW1TCG5T
And yes I ordered one of each to see if there was any difference, and there isn't, so I'll use the other one in my other tractor.
And these knobs: https://www.amazon.com/dp/B07FVLVB55
Supply 12 volts to the delay board, and tap into the green/black wire going to the plug on the switch. Connect this to the Normally Open (NO) side of the relay, and the relay common (COM) to ground.
When the relay fires on the time delay, it momentarily closes the wiper switch wire to ground, which triggers the wiper relay and the wiper arm makes one sweep. Works great. I mounted the relay board in the pop-off cover in the pop-off cover on the roof pillar next to the controls.
You don't need to turn the factory wiper switch on at all, just turn the wiper delay knob to click it on, and turn the knob to set the delay time. The long delay time is really long (I haven't timed it yet), and it's a little touchy, but it's not that big a deal - and it works.
  • Good Post
Reactions: J&K
   / Adding intermittent wipers to a CK4020SE (or any cab model) #17
.When the relay fires on the time delay, it momentarily closes the wiper switch wire to ground, which triggers the wiper relay and the wiper arm makes one sweep. Works great. I mounted the relay board in the pop-off cover in the pop-off cover on the roof pillar next to the controls.
(y) Would you please add a picture of mounting location? I’m having a hard time visualizing it.
   / Adding intermittent wipers to a CK4020SE (or any cab model) #18
I've been traveling all week and haven't been home, but I'll add a pic when I get home this weekend.
   / Adding intermittent wipers to a CK4020SE (or any cab model) #19
I just realized I should have linked this thread
   / Adding intermittent wipers to a CK4020SE (or any cab model) #20
Here's what the install looks like. I might work on the light bar and side light wiring this weekend, and if I do I'll get pictures of the wiring and switch mount etc.
2000 Chevrolet C8500 Flat Bed with a Moffet Kit - CAT 3126 Engine! - (A55218)
2000 Chevrolet...
2008 UTILITY VS2DX DRY VAN TRAILER (A54607)
2008 UTILITY VS2DX...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
2019 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2019 CATERPILLAR...
