/ John Deere showing codes #1
rooster1980
central texas
john deere 5085M, john deere 1025R, Massey Ferguson 2607H, Ford 3600, Allis Chalmers G new holland TS110
2015 john deere 5085m keeps throwing code ECU 3673.07. It worked fine last fall, it’s been sitting pretty much all winter. Thanks in advance
/ John Deere showing codes #2
Exhaust throttle valve not responding or out of adjustment. I don’t know what that means, maybe something to do with emissions controls.
yes, i believe its something to do with the emissions. i was wandering if i could take the valve off and clean it.
/ John Deere showing codes #4
Did you jump start or change batteries since last year? Most everything I have read points to ECU.
Yes, the battery went dead a few months ago. i charged the battery and it worked fine. i havent reallly used it much all winter, i use a different tractor to feed hay and stuff with during the winter. i usually just use the John Deere to pull a disc cutter with.
/ John Deere showing codes #6
Does it run normally? Or is there an actual performance issue too
/ John Deere showing codes #7
It seems there is more of a danger burning out the ECU/ECM when there is electrical disruption. Either jump starting, starting with a bad battery, or charging issues seem to risk the electrical components.
the battery is the original battery. it is 9 years old but the tractor starts fine.
/ John Deere showing codes #10
I wonder if you could remove the battery for a while and then repower to see if that would reset the CEL
i unhooked it for about 5 minutes it didnt help anything. you think a new battery would help.
/ John Deere showing codes #12
A weak battery can cause screwy things. At 9 years old it’s on its last leg anyway.
yeah, ive never had a battery last that long. not even in a new truck or car.
/ John Deere showing codes #14
I replace ALL my batteries ever 5 years no matter what. Sounds to me like it's dealer time...lol
One thing I always do is I install a master disconnect on the NEGATIVE post of all my starting batteries unless I have them on a trickle charger when parked. If you break the electrical circuit and the battery sits all winter with no parasitic load on it, your ECM is always drawing power, the battery will retain almost all it's power for a long time.
I read somewhere that a starting battery retains it's power (when charged fully) and sitting but out of circuit, it looses about 5% per month and a dead batter in the winter will freeze if it's below freezing and once they freeze, they are basically shot. I a fully charged battery can withstand 40 below no issue.
Batteries, like everything else today, ain't cheap, especially the Group 31, 1000 CCA ones I use. I keep my diesel pickup truck and the side by side on a battery tender all winter. I only use Interstates and I buy them from a local truck dealership because they have high turnover. All wet charged batteries when sitting on the shelf are using up their useful life. I never buy any batteries if the top is dusty, a sure sign they are old and getting feeble and when I replace them, I always trickle charge them before installing as well. They will all need to be 'topped off'
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
case 370 glass door never installed (A61307)
case 370 glass...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 GMC Sierra Z71 (A62679)
2015 GMC Sierra...
Volvo VNL (A63689)
Volvo VNL (A63689)
213137 (A64276)
213137 (A64276)
