Pallets in fields
   / Pallets in fields #4,262
From another thread
   / Pallets in fields #4,263
Wonder if it is a felony “want”…..
   / Pallets in fields #4,265
As a teenager we used to trap fox by putting a bale of straw out in the middle of a field. They like to climb up on things to improve their view. Farmer may be trying to get rid of groundhogs or other pests and wants to attract fox.
Stack wood into piles to serve as a shelter. Find a dry, breezy spot 6 to 9 m (20 to 30 ft) away from your home. To keep the wood dry, place a log rack or a wood pallet there. Then, stack firewood logs next to and on top of one another to build an even stack. Top the pile with a firewood cover to keep it dry. If the wood is spaced well enough, it can be a place for a fox to hide or even live, but it’s mainly to make your yard feel more like the woods.[7]
  • Wood piles add a natural element to your yard, but foxes sometimes live in or burrow under logs. If you have a large property with plenty of trees, you could leave old logs or branches in the hopes of drawing in foxes.
  • Wood piles also serve as shelters for other creatures, including mice and rats, so be sure to keep them far from your home.
   / Pallets in fields #4,270
2002 Ford F-650 Landscape Flatbed Truck (A56858)
2002 Ford F-650...
2012 LAND ROVER Range Rover SUV (A56859)
2012 LAND ROVER...
Kubota BX25D (A53317)
500BBL WHEELED...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
