Lets make a Quick release front rake....04-14-2024, it works great!
   / Lets make a Quick release front rake....04-14-2024, it works great!
Your correct (both of you) bush hog on small hp tractor can grab these vines, some are from the 70's....and wraps it tight absolutepain in the arse when you hit them and trees start swaying as vines wrap up, now that the vines are out of the way I can bush hog them until we spray them.
Now I have to check bush hog gear box ratio and rebuild it with bearings and seals....and remove the sawdust oil looking oatmeal out of it.
I do like the front mounted brush hog idea, I guess add 2 wheels to the deck so it rolls on them and the stock wheel?
   / Lets make a Quick release front rake....04-14-2024, it works great! #22
Love your idea sir!!!
I may steal/modify.
I’ve got plenty of angle/tube in the barn and a pile of 6” square 1/4” plates……
Make sure to tag me for a picture of yours ;)
   / Lets make a Quick release front rake....04-14-2024, it works great! #24
Of course!
Did you post the link for the SSQA plate?
Debating on buying one or making it slip on my bucket and ratchet strap it on.
   / Lets make a Quick release front rake....04-14-2024, it works great! #25
Saw your posts on ARF as well.
So used it extensively this weekend, it rocks!!
DURING, had some wire to cut out also, 1st layer is out.
THE AFTER PICTURES
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
John Deere 6110M (A53317)
John Deere 6110M...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
