Bolens G174: input shaft spline
/ Bolens G174: input shaft spline #1
Rod in Forfar
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
They don't break if you don't use 'em.
Yesterday the Bolens G174 hauled several loads of hardwood blocks out of rough terrain in the woodlot and dumped them in the yard for splitting. The Kubota B7510 with its remote works very well on the 3 pt. hitch splitter, btw.
Today as I pulled away from the shed with the dump trailer in tow, something started making a loud, scratching noise in the tunnel between the clutch and the transmission, and the tractor wouldn't move. I immediately associated the new fault with the hydraulic work I'd done last week, or with the Asian dump trailer.
Turned out it was a stripped spline boss on the input shaft. That's a female version of the input shaft spline, a piece of aluminum with two 5/32 spring pins through it.
An entertaining afternoon on the floor of the shop eventually led me to that conclusion. An Allen wrench slid through the pin holding one end of the spline boss allowed everything to turn properly again. But either the spline or the boss must be stripped for the input shaft to spin, so replacing the pin likely won't do.
Now I'm at the parts-acquisition stage: Does anybody know how many splines are on an input shaft? Are these a standard item, or Iseki-specific? Anybody have a source for the boss and the spring pins? Any suggestions as to how to get the broken pin out of there?
Thanks, Rod
/ Bolens G174: input shaft spline #2
I had that problem with my G154. I bought a new spline boss $120
and the input shaft was stripped also. I welded the input shaft
along each spline and re-splined the shaft with my dremel.
here is a video of some of the details. You'll have to
split tractor to get the old spline boss out.
Bolens/Iseki Clutch Problems. G154 / TX1300F - YouTube
That's a terrific video for someone like me who doesn't know what the inside of a tractor looks like. Somehow the parts diagrams don't make much sense on the page, but when I see the thing opened up on screen I have a much better idea of what I'm getting into.
So it looks as though I'm in for a tractor-split in the near future.
The lesson for me is that the Bolens G174 isn't supposed to do the kind of pulling a full-sized tractor does. Mine has run the pto for hundreds of hours over three years mowing and bush hogging, but one hour with small dump trailer with a few hundred pounds of firewood on it over rough terrain, and it's spline-boss repair time.
Oh well, the Massey Harris 30 has been feeling neglected lately, and it starts better in winter. No hydraulics, though.
/ Bolens G174: input shaft spline #4
Any time the tractor is running and doing anything like just driving or mowing
or bush hogging that spline boss is working. Just pulling the dump trailer
did not in its self wreck the spline boss.
/ Bolens G174: input shaft spline #5
Intetesting video. Looks like someone buggered things up pretty good in the past. I agree that it was only chance when that break finally occurred. What you were doing at the moment likely had little bearing on it.
/ Bolens G174: input shaft spline #6
I was gifted a G174 because of that problem, old owner didn't wanna throw any money into it so gave it too me.
Back in 2011 before my neighbor gave me the tracter I looked into buying a new (old stock?) input shaft and spline boss from japanesetractorparts.com, the input shaft was $361.00 and spline boss was $131.00, not sure what todays prices are but will find out this spring when I order them myself.
If you got an allen wrench through the holes it's possible the spring pin was lost some time ago like what happened to mine.
The pin sheared off when the teeth on the spline boss failed. I had to drive the centre of it out before I could reassemble the unit.
How do you know you need the input shaft? I think the spline boss is a bit softer than the shafts. In my case it was the rear half which failed and the boss was nearly smooth but there was enough left of the teeth on the shaft to the transaxle to hold well and likely for some time. The spllne boss and two pins I bought from Sonny's Bolens ended up costing about $160 with shipping and exchange. I think it started at $131.00. Interestingly, one of the pins we took out to disassemble the front drive shaft was the wrong size, likely 1/8" rather than the required 5/32".
Remember to wire the pins as you go on reassembly. There's no room to do the spline boss pins retroactively.
Rod
/ Bolens G174: input shaft spline #8
Rod
When the tractor failed back 4 or so years ago my neighbor talked me into towing it to my place to see what was wrong, I had to remove the front driveshaft to get a good look at what was going on and noticed the input shaft was almost wore smooth and assumed the spline boss was just as bad. I told my neighbor how much the parts would cost and he balked for a few years then his daughter bought him a new compact John Deere then I was gifted the Bolens.
All the wires were still in place on my spring clips but the one that was missing then failed as there was no remnants of a spring clip in the input shaft.
I haven't broke my tractor apart yet as I was hoping I could get by cheap till I had time to fix it properly. I welded the input shaft and spline boss together and it lasted most of the summer, I moved to a large farm about mid summer and 17 or so acres by the house wasn't mowed in over a year and my weld failed while attempting to mow what was closest to the house, 3 foot or taller grass and going up a steep hill was more than the weld could handle, if I would have broken it apart to get a better grind and weld I feel it may have lasted, not much room in that tunnel to get a good grind or the tip of my mig into.
The tip of the input shaft broken off with the weld so I threw a few small stitch welds on so I can move it around under it's own power, not going to risk possible damage by re-welding it so will fix it right next spring, I'll probably sell the Bolens after I fix it as I need a bigger tractor where I live now.
/ Bolens G174: input shaft spline #9
How many hours on these when failure happened?
/ Bolens G174: input shaft spline #10
The one gifted to me was used every summer for around 20 years to mow 2 fields, one around 4 acres the other around 8, hour meter stopped working long ago so I would think a couple thousand maybe.?
Mine was cared for very well though, oil changed every spring, always lubed, the implements wasn't so lucky except for the mower deck, it was used the most so was well maintained.
/ Bolens G174: input shaft spline #11
@fxrs55 I have the same spline boss and transmission input drive shaft problem and want to fix it on my Bolens/Iseki G174. samsbolens.com has most of the parts I need with the exception of the front bearing on the input shaft and the roller bearing, so I'm wondering what would be the likelyhood of reusing the bearing from the old shaft. From what you saw with your repair, would it actually come off the shaft or is it press fit and no chance of getting it off without destroying? I'm hoping the roller bearing can be re-used and have reached out to Sam to see if he can order another. It's going to be a costly repair, but worth it in my book. The Bolens has been a great machine to have around and I want it to be around another 38 years. Here's my parts list so far:
spline boss
1863520
$142.37
input gear shaft
1871589
$387.13
front transmission gasket
1871571
$19.76
gear shifter gasket
1871609
$19.53
bearing 1 ?
1860601
bearing 2
1860606
$21.44
oil seal (not sure if needed)
1860731
$13.46
roller bearing
1860621 ?
/ Bolens G174: input shaft spline #13
If you go to Agco tractor parts you can find those bearings.
Your tractor was also sold as a White Field Boss 16
/ Bolens G174: input shaft spline #14
Thanks for the info @fxrs55... very helpful and much appreciated! I was surprised how easily the shaft came out of the transfer case with a brass punch and the bearings came off the shaft with a chisel. While I could reuse all of the bearings, there is a little play in them so I am going to get new ones to help prolong the life of the Bolens.
Kuhn FC400RG (A60462)
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
DEUTZ MARATHON...
2015 DODGE RAM 3500 4X4 CREW CAB PICKUP TRUCK (A59904)
2015 DODGE RAM...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
