F pedal check
/ F pedal check #1
karlmagne
Ford 1210
I have an RK 37 H tractor and I cut grass in about two acres yesterday. As I was putting the tractor away I noticed I had an “F pedal check” notification. What exactly does that mean and is it something I can do myself?
/ F pedal check #2
Good luck.
Since you were cutting grass I would look underneath the tractor in the area of the forward pedal for a wire pulled loose from a sensor. Or move the forward pedal up and down. Most hydro’s will also not start when the forward or reverse pedal is out of the neutral position.
/ F pedal check
Thank you, I'm a tractor noob and I did a cursory glance, but didn't think wire. I'll do a more thorough check.
/ F pedal check #4
Gator might be into something. On the HST pedals linkage there is a sensor that detects whether the pedals are in Neutral position.
I don't know if that transmission is mechanical or electronically controlled. If electronic, there could be more electric stuff there.
/ F pedal check
Thank both of you for your responses. I did a more thorough inspection and found that the pedal rod/linkage has a short post on the end of it had slipped out of a metal clip (it has an open end). I reattached them and the notification went away. There are some small sapling in the field I mowed and one of them probably forced them apart. I did see wires and connectors and will keep them in mind as I mow.
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2005 Chevrolet Express Van, VIN # 1GCFG15X351255714 (A65563)
2005 Chevrolet...
1979 Log Trailer MODEL JCV040 40ft Long 65000 GVWR (A62679)
1979 Log Trailer...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
New Holland 311 Square Baler (A66408)
New Holland 311...
20' One Trip Shipping Container (A66285)
20' One Trip...
