Bale Fork for Moving Pallet?
/ Bale Fork for Moving Pallet? #1
Mike_in_Missouri
New Holland Workmaster 120 (decoration?), Massey Ferguson 135 (does all the hay work)
I have a 2-prong bale fork and was wondering if I can use it (in a pinch) to move pallets. Buying a separate pallet fork for said purpose doesn't make sense, given the infrequent need, but my hay fork is used quite often. Thank you.
/ Bale Fork for Moving Pallet? #2
I do it all the time, also use them as log carriers. Or last week as concrete railroad tie movers.
/ Bale Fork for Moving Pallet? #3
Depends on how heavy the item on the pallet is…
/ Bale Fork for Moving Pallet? #5
My bale spears are rated for 4000 pounds each at the midpoint and I use 2. My loader will only lift ~1700 pounds so I feel well within the safety margin.
I don’t imagine what your spear attaches to is rated for 8k. But if all you own is a WM 120 I would say it lifts more…
/ Bale Fork for Moving Pallet? #6
I miss type Standard bale spears are rated for 3K - 3.5k at mid point for each spear. I just have little LS XG3135 it won't exceed that in it's lift rating. But I can stack logs on them. Also just carried a 20' long 24" Stand pipe that worked the tractor a bit and was a touch wobbly. My spear frame is rated for 4k
Amazon.com
/ Bale Fork for Moving Pallet? #7
I figure the spears have to handle big square bale pushing 2k dry more if rained on.
Sounds like it'll meet my needs well. Thank you!!
/ Bale Fork for Moving Pallet? #9
I had a 3 prong spear at my last house. It had one main spear and two smaller spears to act as keepers (for lack of better term) to keep the bale from spinning on the main.
I could move large round bales no problem, but obviously it wouldn't move pallets. Curiously, I ended up (and still do) using the pallet forks more often than just about anything (except winter time snow removal).
No livestock or hay bales at current house, but I sure do use those pallet forks often.
/ Bale Fork for Moving Pallet? #10
I'd imagine bale spears would hold up well. That's what I used to build my brush forks and they're quite robust
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
Adams Weight Hopper (A63688)
Adams Weight...
213087 (A64276)
213087 (A64276)
Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
Kivel 48in Forks...
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
2024 DOUBLE A TRAILERS 10226T7KGN GOOSENECK TRL (A64280)
2024 DOUBLE A...
