1/2 inch vs 13 mm.
/ 1/2 inch vs 13 mm. #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
I've always used these interchangeably, although the metric is slightly bigger.
(+- 2%) Yet 1/2" is too small for the nuts on the bar for my Echo saws. Yesterday I was tightening the tailgate latch on my pickup and found that 1/2 was too small for that, also. Apparently my 1/2 inch sockets only identify as metric.
/ 1/2 inch vs 13 mm. #3
Its a stretch to use those two interchangeably. On something that isnt super tight or rusted....sometimes I grab a 13mm if I see that wrench/socket before I see the half.
Half is a TIGHT fit on some 13mm stuff and a good choice if your worried about rounding. But those two really "shouldnt" be interchanged. But several others are MUCH closer....commonly:
8mm - 5/16..........0.315" - 0.3125"..........+/- 1%
11mm - 7/16........0.433" - 0.4375"...........+/- 1%
14mm - 9/16 ........0.551 - 0.5625"..........+/-2% (this one is almost as bad as 1/2 vs 13 mm)
16mm - 5/8" .........0.630 - 0.625.......+/- 0.8%
19mm - 3/4" ...........0.748" - 0.750....+/- 0.3% (dead ringer given mfg tolerances. Im convinced they are the SAME mold just labeled differently)
22mm - 7/8............0.866 - 0.875.... +/- 1%
24mm - 15/16......0.945 - 0.9375....+/- 1%
The metric "bastards" with nothing close are 10,12,15,18.....and those are VERY common if you wrench on cars and small equip
/ 1/2 inch vs 13 mm. #5
I've used them interchangeably quite a bit. I do have one car that has a square female 13mm oil drain plug. So, the 1/2" socket drive is the choice for it.
My latest purchase is a Land Rover, and I'm now discovering that I should purchase whole new Whitworth wrench and socket set.
/ 1/2 inch vs 13 mm. #6
Bolts on tail gate could be metric also.
/ 1/2 inch vs 13 mm. #7
I believe it all depends on how tight of tolerance the sockets are made to more than anything else or how worn the socket is as well. Sockets do wear out, especially on an impact wrench.
/ 1/2 inch vs 13 mm. #8
Anything 1/2” or 13mm I bring both wrenches or sockets and use whichever one fits tighter, to avoid possible damage to the nut or bolt.
I do the same for 3/4” and 19mm.
I’ve done this for years. It’s second nature now
They are,as I found out yesterday.
When I got my first socket set for Christmas many years decades ago they didn't include a 13mm. Or maybe it was 1/2 inch.
/ 1/2 inch vs 13 mm. #10
Welcome to the true joys of British engineering. And, yes, I would purchase the sets. Too much heartache and skinned knuckles trying to find something "close".
All the best,
Peter
/ 1/2 inch vs 13 mm. #11
what is the 4mm then ?
/ 1/2 inch vs 13 mm. #12
I just put together some chairs where the instructions said to use either a 1/2 or 13mm wrench.
Since I’m guessing the chairs were made in China I used 13mm.
It all went fine.
/ 1/2 inch vs 13 mm. #13
That's weird, one of the more common bolt sizes. Some socket sets seem to leave out a 16 though.
Can't say I need a 12 much, but the others...yeah.
/ 1/2 inch vs 13 mm. #15
With a 12mm and 14mm I can almost totally disassemble my '92 Toyota pick up truck.
Patrick
/ 1/2 inch vs 13 mm. #16
This drives me nuts when i service valves on Generac air cooled engines. About half the time my 1/2” crowsfoot wrench wont work and i have to use 13mm. Maybe 50% of the time. The engine is made in USA…..
should not need metric anything. But they switch between both standards throughout unit.
/ 1/2 inch vs 13 mm. #17
And my HF Predator engine has American threads on the mounting holes near the output shaft. And you know what country that was made in...
/ 1/2 inch vs 13 mm. #18
I only use 6-point sockets. Problem solved.
/ 1/2 inch vs 13 mm. #19
All the best,
Peter
Does that include British Pipe Thread? Man I can stand it when they use that.
/ 1/2 inch vs 13 mm. #20
4 / 25.4 = 0.1575"
A hair bigger than 5/32" but now your talking hex-keys most likely if you are working with stuff that small. And with hex heys....about the only ones I will interchange are 8 and 5/16. Cause aint much worse than a rounded out hex-key or bolt
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2010 GMC SIERRA 1500 (A67714)
2010 GMC SIERRA...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
