The Resting Place.
   / The Resting Place. #1,041
I try and make it a point to always use handrails on stairs for the past several years. :confused:
Same here. I'm trying to NOT be a tread topic here...
   / The Resting Place. #1,043
Ladders are one of the most dangerous tools many of us have.
I learned from a friend to tie a ladder at the top to gutter, limb, something. I need to go up & down an extension ladder within a few days on 2 story garage. Last time I ratchet strapped it to a post, one high & one low. I have a safety harness also I may rope to the cupola.
   / The Resting Place. #1,044
That makes sense, especially as we get older. It's so easy to fall and injuries can be so irreversible. If I have to go up now, I get a neighbor or some other volunteer and I watch from below.
As mentioned earlier, I know of four guys in the last year that have died as a result of falls.
   / The Resting Place. #1,045
Yeah, I read that.
I know two folks that died as results of head injuries from falling down steps. :(
If you fall and bang your head hard, you should go to the ER for a CT scan of your head and upper spine. A brain bleed can easily be fatal.
It's a hassle but being dead is a pretty big hassle for both us and the people we leave at home.
   / The Resting Place. #1,046
   / The Resting Place. #1,047
By plan all 5 of my house and rentals are single level with no more than 4/12 roof pitches. Not that a person can't get killed falling from a 1 story, but 2 stories and up and 5/12 and up I tend to freeze or won't go. And to think I used to walk steel beams in construction 100 feet in the air with no fall protection, the only thing mandated back then was a hardhat. :ROFLMAO: :ROFLMAO:
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2007 Case IH 8010 4WD Combine (A50657)
2007 Case IH 8010...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A51039)
2015 Ottawa Yard...
