F3990 vs newer F3710 4wd front deck mowers
   / F3990 vs newer F3710 4wd front deck mowers #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Will both machines come out of 4wd ?
Both are basically same HP I think.
I think I’ve got one of my ZD1511 sold & wanting a 4wd for steep banks.
I don’t necessarily like the front deck running on the ground because I have rough farm Ground.
Regens are no issue as I mow 3-6hrs at a time 2 & 3 times a week.
I love my two ZD1511 72 with fluid filled rear tires but needing a 4wd in places.
   / F3990 vs newer F3710 4wd front deck mowers #2
I thought you just said you loved your ZD-1511??? But seriously, I know what you mean. The front mowers can take uneven ground up to a point, then you have to slow down.
My 3680 is part time 4WD (you woudn’t know it was on) or locked in 4WD and you know it’s on.
What about putting bar tires on one of your 1511’s? That was a game changer for traction for me
I do love both my ZD1511 but need a 4wd in places.
These zero do pretty well with fluid filled rears for traction & front weights to keep front end on the ground.
I’m wondering if any dealers has a leftover F3990 for cheap ….
   / F3990 vs newer F3710 4wd front deck mowers #5
Try Bar tires. A set is like $300.
Might be all ya need
I don’t think they’re available in 26x12-16
I think a 4wd & my ZD1511 would be a perfect combo for my application.
   / F3990 vs newer F3710 4wd front deck mowers #7
   / F3990 vs newer F3710 4wd front deck mowers #8
I had them on my ZD-331.
Maybe your 1511 takes a different tire?
   / F3990 vs newer F3710 4wd front deck mowers #9
:ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
An F series for cheap, especially a F3990. Good luck
Yeah, that’s true.
5 years ago a 3990 was $29,950.
I bet the new equivalent is $35,000
I meant cheap as in a couple thousand off on a new leftover F3990.
I can buy a new F3710 for $29k
I just need to find out the difference between the two models ?
Wheels & Dash are different colors by pix.
Specs looks identical on both machines.
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2025 Forklift Safety Basket (A56857)
2025 Forklift...
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
LOT OF PIPE W/ PAD ON END (A58374)
LOT OF PIPE W/ PAD...
