You Know You Are Old When
/ You Know You Are Old When #1,701
We can pretty easily live with only one car in Fla. Most of the stuff we do and places we go can be accessed by golf cart or bicycle (tennis, golf, bike trails, restaurants, friends).
I worry that leaving a car in Fla. (in the garage) for 5 months will not be great for the car. I would remove the battery and put in air conditioned space.
What else would you do?
I'd get the weight off the tires, put a heavy dose of sea foam in the fuel tank. Possibly invest in a cover even if indoors, and dryer sheets in the interior floor in several spots.
/ You Know You Are Old When #1,703
I'll find out what they do, next time I speak with him. I had thought he just disconnects the battery and leaves it in place, but I'm not sure. If it were me, I'd probably just connect it to a battery tender, and leave the car live, easier than reprogramming everything every time I return.
I know many of their friends do this dual-residency things, so there's lots of combined knowledge on how to leave home and vehicles unoccupied, with minimal damage. I know they use wifi cameras (e.g. Ring) aimed at thermometers in various parts of the house, and check them daily to be sure heat is working, etc. They also charge up their sprinkler system and then shut off the incoming water to the home. That might not work in houses with a boiler on an autofill valve, without moving the boiler upstream of the shutoff, but they have heat pumps.
/ You Know You Are Old When #1,704
I know he's not jacking up the car. I know this was a big issue with bias ply tires, developing flat spots, but I always thought radials were more forgiving of sitting a few months.
The company that makes Race Ramps makes tire caddies that you can park on, keeping the load on the tire more evenly distributed, if it's a real concern:
/ You Know You Are Old When #1,705
She's old school.
She was home last week and asked me to show her how the tub and sink drains in the house work. :oops:
Who is this kid? :ROFLMAO:
My guess is she's the daughter you raised and it looks like you did a great job. 🏆
/ You Know You Are Old When #1,706
I thought that as well but found my 18.4 x 30 metric sized radial farm tractor tire developed a flat spot from sitting over the winter with too low of pressure. This is a multi thousand dollar tire and even at 100% tread they considered it "out of warranty" when replaced. Thanks for nothing.
The preventative is to overinflated the tires in storage and move the vehicle a little if you can. My tires were run at 8 psi and I now inflate to 22 psi over the winter.
I'm told you can sort-of make a flat spot in a radial go away or at least better by inflating correctly and then driving highway speeds for a while. Then, keep the pressure correct and add air over winter. Problem--knock, knock--is apparently solved.
/ You Know You Are Old When #1,707
My zero turn tires are kept around 12 psi, and they definitely develop flat spots over the winter. But honestly, ten minutes into the first mowing of each season, they're pretty much gone! Granted, I'm not doing road speed on a zero turn, but they're also bias ply tires.
/ You Know You Are Old When #1,708
My in-laws used to be snowbirds. All they did was disconnect the battery, and the car sat outside.
/ You Know You Are Old When #1,709
The cars seem to do fine in your garage with battery disable or on trickle charge. I leave my golf cart plugged in for 8 mos we're not here.
(INOP) MASSEY FERGUSON 543 TRACTOR (A59823)
(INOP) MASSEY...
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2017 Kia Soul SUV (A59231)
2017 Kia Soul SUV...
1981 Mack DM492S T/A Flatbed Fuel Transport Truck (A59230)
1981 Mack DM492S...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
