What size auger bit do you use the most?
   / What size auger bit do you use the most? #11
I have 6", 9" and 15". I use the 6" and 15" bits the most. 15" allows room in the hole so I don't have to cut the top treated rail when doing end braces. They last longer when not cut. Posts are concrete.
   / What size auger bit do you use the most? #12
I gave up using an auger on my tractor. I have a NH skid steer with a 36" auger we plant trees with. I also have a 18" auger if we are doing post frame building or fence posts.
   / What size auger bit do you use the most? #13
Building fences in the past, I think we tried a few different things. One of the more effective things was to pre-drill post holes with something like a 4" to 6" auger slightly smaller than the posts, then to push the posts in. Dad liked pounding with the bucket, I wasn't convinced. But, eventually they bought a 3pt mounted post driver which worked well. Anyway, driven posts were probably better than drilling oversized holes and tamping the posts in.
   / What size auger bit do you use the most? #14
I have a hydraulic FEL mounted post hole digger, so similar except you can see better. Much easier than 3 point and best of all, you can reverse the bit. Plus, it will simply stall out hydraulically if the bit hits a root or rock.
   / What size auger bit do you use the most? #15
I have a 6" and a 12".
The 6" gets used for setting 4x4 posts for fences and trellises.
The 12" gets used for deck footings and planting trees.
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A55314)
2006 Heil Tanker...
2007 International 4300 Dump Truck (A51692)
2007 International...
Eagle Weathervane (A55853)
Eagle Weathervane...
2016 Ford Transit 250 Cargo Van (A53422)
2016 Ford Transit...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
