Buying Advice First tractor for small family farm. Branson or something else?
   / First tractor for small family farm. Branson or something else? #61
By the time I realistically get into making hay, I'll have two sons at hay throwing age. Round bales aren't super high priority.
My biggest thought with the cab is honestly health and safety. I'm prone to burning in the sun and would prefer to have my ears and lungs fully functioning as I age. Realistically I'm not going to consistently wear hearing protection or a mask when in heavy dust, and I'm known for forgetting sunscreen. The warm and dry are just gravy to me. I also have little use for the tractor in the woods, so I don't need to worry about cab damage from above.
Cab is a must
I have a 2007 Branson 6530, 4wd with loader and cab, I bought new and one of the reasons was the Cummins licensed engine (now described as the Kukje engine)....all mechanical. Not sorry.
Recently I was looking for another tractor, used, in the same or slightly larger HP and found used TYMs with a couple of different engines which were built prior to the Branson buy-out. The engines were first class, just not Cummins licensed (Yanmar and Perkins). Thought seriously about pursuing them but being fairly new and distant, I looked for something older and closer which I found in a Case-IH 895 with cab.....cheaper and delivered.
I run a 5x4 round baler that produces at least an 800# bale (weighed one once) and the 65 HP (57 PTO) is necessary for running that baler. A 4x5 bale is said to be heavier if considering that. Square balers have low HP requirements and a 35 HP tractor can get that work done.
The cab with AC and heat and both are nice baling and delivering bales in the winter. 4 WD is pretty common on newer tractors these days and I had a 100 HP JD 4230, 2WD having bought implements for it to use and I can use them with my Branson in midrange gears as was the case with the JD.
Open station tractors are usually easier for a lot of get-on, get-off work and of my 7 tractors (25-84 HP) most are open station.
I bought my farm as a city boy in 1979 and I am still learning something new just about every time I do something. Maybe that's why I like farming.....not boring.....something different every time you attempt something and problems require thought to get solved.
Good luck on your pursuit.....and be safe......don't take chances.
Buyers who start with an open station and later buy a cab machine very often say they wish they had started with a cab. You will use the tractor more often and will benefit greatly with not having to shower after a 2 or 3 hour task and not having to freeze on the coldest winter days. And then there is noise...I might have avoided hearing aids if I had a cab the first 10 years of tractor ownership!
In our area the local farmers who have haying equipment will cut, rake and bale for reasonable fee or % of the hay they put up and so I sold my rake, baler and wagon after a few years...I kept the sickle bar mower for road bank mowing. Disk mowers are better for haying; but much more costly to buy.
I would start with a chassis size equivalent to a 5000 series Deere, a little larger than being discussed I believe. I like a 65 hp class tractor as it is conservative on fuel usage; but sufficient for my needs. Large diameter front tires really smooth out transport across a less than flat field.
   / First tractor for small family farm. Branson or something else? #62
I wear noise cancelling earbuds on the tractor and listen to music. I wear hearing protection with a lot of power equipment in fact. You can still avoid hearing loss by taking precautions
   / First tractor for small family farm. Branson or something else? #63
I have 32db ear muffs sitting on the joystick of the tractor. They go on my head before I start the engine. My hearing is still good after 4+ decades of motorcycles, chainsaws, guns and loud music because I wore hearing protection most of the time.
For the majority of my adult life, we've lived places that needed little to no outdoor work; apartments, townhouses, etc. Now that we finally have some land I'm back to doing things like cutting grass, that I haven't really done since I moved out of Dad's house. I've been putting my headphones in and turning up the volume, which may in fact be worse for my ears. I recently bought a set of bluetooth hearing protection headphones for use on the zeroturn so I hope any further damage will be limited.
   / First tractor for small family farm. Branson or something else? #65
Being in the service we never had any thing like head phones etc. And being around jet planes kicking in the afterburner and large prop planes it does a number on your hearing. Being in a
cab cuts the noise down and with my head phones you can barely hear the tractor running.
willy
Delivered this afternoon. Unfortunately I had too much scheduled at work and didn’t have much time to play. I’m really looking forward to getting a lot done with this thing.
   / First tractor for small family farm. Branson or something else? #67
Very nice. I am sure it will serve you well for many years to come!
   / First tractor for small family farm. Branson or something else? #68
Now you just need a hydraulic top link!
   / First tractor for small family farm. Branson or something else? #69
Very nice RiverHill . . . (y)
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
2023 John Deere 333G for Parts (A56436)
2023 John Deere...
Enmark Z Spray (A53316)
Enmark Z Spray...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
