555dtc rear brake boot
/ 555dtc rear brake boot #1
FF/P
Montana 555dtc
I have a Montana 555dtc with a leaking rear brake boot. When the tractor is running it sprays hydraulic fluid out under pressure. My question is should the rear axle have pressure? If not is there a vent that might be clogged or should I be looking for something else? While I have experience working on engines, working on tractors is new to me. Thank you for your input.
/ 555dtc rear brake boot #2
Typically there should not be any pressure in the transmission housing or axle area where the wet brakes are usually located. I do not know your model well but if you include some pictures of where the leak is and also let us know if it is a geared or hst transmission, someone here might be able to chime in.
It’s geared, not hydrostatic. Sorry for the poor quality of the pictures.
Better pic
